Hi I am very new to this so please go gentle.
I installed ATVUSB creator.
I then updated the software for XBMC and intially it ran fine, except that the window was tiny and I had to stand in front of the TV to see it. So I changed to maximum resolution. I also turned on SMB (I think)
When I navigated back I got 'XBMC exiting with status 10
I tried it again but kept getting the message so then I downloaded the update again, where by its loaded the media centre logo (Bigger this time) but crashed the appleTV.
Any ideas?
after restarting it exits with status 5.
sigh.
Need to see the console.log
ssh in
sudo find / -name console.log -print
scp this file out and stick it to
http://pastebin.com/ and post the URL.
Hi thanks for the response, how do I ssh in?
with the applecore one I could log in as AppleTV.local, but this does not appear to work with the atvusb one.
ssh -1 frontrow@<IP of the AppleTV>
like this
ssh -1
[email protected] where 192.168.9.12 is the IP of MY AppleTV not yours.
having the exact same problem..
please help totally new to this
only getting exiting with status 10
johanbolle Wrote:having the exact same problem..
Maybe try exactly the same. Please provide some logs. See
DebuggingHints on how to do it.
dont really understand .. sorry really new to this
johanbolle,
you will need an ssh client. If you are on OSX or Linux it is included. Open your terminal and enter
scp [email]frontrow@
appletv.local:/Library/Logs/Console/501/console.log[/email] .
appletv.local:/Users/frontrow/Library/Logs/xbmc.log[/email] .
This will copy 2 files to your current directory. Paste them to
http://pastebin.com/ and the links to it here.
HTH
johanbolle Wrote:is this right or?
http://pastebin.com/d75a6af6c
yeah, scp, perfect. Now try to copy the files to your machine.
If you already did, maybe paste here what happened/you typed.
johanbolle Wrote:to my machine??
sorry, to your local computer
Try this where you did scp before:
appletv.local:/Library/Logs...01/console.log[/email] .
then this:
appletv.local:/Users/frontr.../Logs/xbmc.log[/email] .
nope dont understand
i give up
can i delete the xbmc from my apple tv or is it stuck there, this was a bit out of my leauge
johan
