2008-10-02, 20:44
Hi folks,
I discovered that XBMC was available for mac last night (how long has that been the case?) and was excited to test it on my macbook pro and be met by generally a very nice feeling media frontend.
I'm going to install it on the mac mini under the tv later tonight but wanted to ask if there was a way to reduce a slight headache that i have with my media files.
Up until now i've been using frontrow to playback my files, namely ones that itunes/quicktime don't natively support so i've been using perian to load the files (mkvs etc) into quicktime, waiting for it to finish caching the file and then saving the file as a reference file. This mov file can then be added to itunes and used within frontrow.
Frustratingly now I have the problem that when importing the media directory I get duplicates of the tv shows and films I have. Its less of a problem with the tv shows as although the total count is double the size you can only see individual episodes. The movies however show up twice, one for the original file, one for the reference file. The latter can't be ran as its a .mov file that only works via quicktime using perian.
Anyways i wondered if there was a way i could filter out say *.mov from all the files i import for tv and movies. I can remove the files from the library but whenever i refresh the folder to look for new media it just re-adds the duplicates back in again.
Hope its possible. Great to have this software on a machine that has the power for the modern HD formats.
Cheers
Cheers
