2013-05-10, 16:10
assigning key combinations for shortcuts is easy but what were saying is that once youre inside xbmc you cant launch them anymore...
(2013-05-10, 16:10)therock003 Wrote: [ -> ]assigning key combinations for shortcuts is easy but what were saying is that once youre inside xbmc you cant launch them anymore...
(2013-05-10, 16:19)aperfectme Wrote: [ -> ](2013-05-10, 16:10)therock003 Wrote: [ -> ]assigning key combinations for shortcuts is easy but what were saying is that once youre inside xbmc you cant launch them anymore...
With my method you can, I do it all the time!
(2013-05-10, 16:07)aperfectme Wrote: [ -> ](2013-05-06, 20:33)navigates Wrote: [ -> ]Is there a way to launch applications with the remote app? There is an EXE file for which I created a shortcut but when xbmc launches all shortcuts get disabled.
I use this program works pretty well, I have assigned
some shortcuts in PS3 BluMote to buttons for example for the GREEN button ( ctrl+shift+alt+B)
and then I went to HotkeyP to define that when ctrl+shift+alt+B its press it launches XBMC.
With HotkeyP + PS3 BluMote you have endless possibilities.
I hope it helps!
(2013-05-18, 23:47)therock003 Wrote: [ -> ]3 Questions i've been having.
-Is there a way to wake/sleep computer via Bluetooth? Like what sleep on LAN does, but by pressing a key on the remote.
-Also when screensaver is on, and i press a key on the remote, it stays on. Why does remote keystrokes dont affect screensaver?
-Is there a way to add delay to the keystrokes? Like for example i want to have a function that presses alt+x then waits a couple of seconds and then sends s+enter. So i can with one comand, close MPC+XBMC.
(2013-05-22, 02:48)navigates Wrote: [ -> ](2013-05-18, 23:47)therock003 Wrote: [ -> ]3 Questions i've been having.
Let me take a shot at the answers:
Yes I believe you can shutdown or sleep using a shortcut and assign the shortcut to a button. Note for shortcut, you need a small software mentioned above so the shortcut works. If not all windows assigned shortcuts will be disabled once xbmc is on. I use the taskkill shortcut all the time when xbmc freezes on addins.
For wakeup, most PC’s can wake up on lan. So you can use hippo remote to wake up your PC. I haven’t figured how to switch the PC on through the remote. Etc.
Not sure what you are talking about.
You can create a batch file and assign a shortcut and assign that shortcut to a button on blumote.
This is the shortcut software:
http://hotkeyp.softonic.com/
(2013-05-22, 09:36)therock003 Wrote: [ -> ](2013-05-22, 02:48)navigates Wrote: [ -> ](2013-05-18, 23:47)therock003 Wrote: [ -> ]3 Questions i've been having.
thank you for your replies.
1-Well sleeping is easy, ou can indeed send a function and map a button to do it, but i'm mostly interested in waking the computer. It seems that when computer goes to sleep, so does my bluetooth dongle, and i cant use bluetooth to wake. Plus you'd need blumote to kkep running while the computer is sleeping so the commands sent by the remote are recognised. So all of these pose as a problem. One alternative is to use an iphone with special software and do this via wifi as you suggested, but i'd prefer if there was some special way to do this by the remote so i wont haveto keep many devices around me at the time.
2. What i mean is that when a screensaver is active, you either have to move your mouse, or press something on your keyboard so you exit screensaver mode and resume working at your desktop right? Well when pressing a key on the remote this doesnt happen. Basically what i'm saying is this. Screensaver is on, and i press "ENTER" on my keyboard, tehn sceensaver leaves. Screensaver is on and i press a key on the remote that sends a simulated "ENTER" screensaver doesnt go anywhere. So i'm wondering why it doesnt repsond to commands sent from the remote.
3. Well OK but i was hoping for simple functions i wouldnt have to use scripts, so if its possible to add delays to blumote i would like to know about it so i can start using it. If not i will then use hotkeyp or autohotkey.
(2013-05-27, 09:25)therock003 Wrote: [ -> ]I dont know, i'm pretty happy overall with my bluetooth. Its tiny, class 1, 100m reception v4 with EDR. I woulndt want to have to change it
I hope it helps!
(2013-06-07, 06:16)dazz87 Wrote: [ -> ](2013-05-10, 16:07)aperfectme Wrote: [ -> ](2013-05-06, 20:33)navigates Wrote: [ -> ]Is there a way to launch applications with the remote app? There is an EXE file for which I created a shortcut but when xbmc launches all shortcuts get disabled.
I hope it helps!
Nevermind figure it out. I forgot to add "ctrl+shift+alt+B" in the shortcut key under xbmc icon property.
