Full Version: is possible to use xbox 360 wireless gamepad? (with usb dongle)
I have installed ms drivers but can be able to use xbmc with the xbox 360 gamepad
I have seen some documentation about using it on linux but nothing about windows
i have:
Windows XP SP3
XBMC_for_Windows-Atlantis-Beta_1.exe
Microsoft Xbox 360 Wireless controler for PC with usb dongle and drivers working on games
guidoxyz Wrote:I have installed ms drivers but can be able to use xbmc with the xbox 360 gamepad
i have:
Windows XP SP3
with a few carefully crafted search terms, you'll probably find the windows instructions not that far away from where ever you found the linux ones Smile
Just do a search for "360" in this forum Rolleyes
Gamester17 Wrote:Just do a search for "360" in this forum Rolleyes
Thanx bro i´ll do
guidoxyz Wrote:Thanx bro i´ll do
i used xpadder and everything works excelent, thanx to all
