Full Version: WebServer not running in XBMC Live?
Hi all,
I have installed XBMC LIVE onto a USB stick on an IBM Thinkcenter T61 (via the Live CD). I have tried enabling the webserver on various ports, but nothing seems to work. The only real change I've made from the default install is to /etc/network/interfaces to get my wireless working. Connected it to ethernet port to make sure that wasn't the problem with the same result.
Ran a portscan on it to make sure I wasn't doing something funny, and whichever port I try to run the webserver on is never open.
Anyone have any ideas?
Cheers,
EDIT: Should point out that network connectivity is fine - via either ethernet or wireless, I can browse shares from XBMC, and from windows I can SFTP into XBMC.
EDIT2: Running SVN:15613
