2008-10-04, 17:00
2008-10-04, 19:55
Under which folder (directory structure) did copy the skin files into?
2008-10-04, 20:23
under /applications/XBMC.app/Contents/Resources/XBMC/Skin
i manget to install the vinchi skin with no problem but i can't chose the aeon skin
when i am standing on it it tells me that Incompatible skin. We require skins of version 2.00 or higher.
i don't why
i don't why
2008-10-05, 20:11
someone thanks
2008-10-05, 20:16
Hmmm.... Is your XBMC build up to date?
2008-10-05, 22:14
i think so i did what it's said here - http://wiki.xbmc.org/?title=XBMC_for_Mac_on_Apple_TV
it download it automatically
2008-10-06, 05:14
You probably have a folder structure like this "skin/Aeon/Aeon". I did that with Mediastream by accident.
2008-10-06, 07:11
yes
you are right thanks
2008-10-06, 08:09
can someone tell me how to actually add a skin to xbmc on appletv? total noob here
2008-10-06, 08:30
Drop your skins in /Users/frontrow/Library/Application Support/XBMC/skin . If it's a zip file or something, unzip it in the directory.
2008-10-06, 08:36
sorry for my high noob levels but how do i actually place that in that specific directory? is that on the appletv? if so how do i get to that?
2008-10-06, 14:48
2008-10-13, 14:34
I feel really bad for asking this, as I'm sure it's been answered, but I'm not sure how I would add a new skin to my Apple TV. I imagine it has something to do w/ SSH (which I know next to nothing about).
If someone could help me out or at least push me in the right direction I would appreciate it.
Install new skin
1) sftp (ssh file transfer protocol) into apple tv.
server/host=ip port=22
user=frontrow password=frontrow
apps
windows-filezilla
OSX - cyberduck
2) browse to "/Applications/XBMC.app/Contents/Resources/XBMC/skin"
you may need to browse back a few times to get into the root dir
3) just drop them there and restart XBMC if it was running
4) in XBMC goto system->settings->appearance to change skins
Change RSS feeds
"RssFeeds.xml" is located at "/Applications/XBMC.app/Contents/Resources/XBMC/userdata"
Copy to your computer. Edit it and save to back to the apple tv. (make sure to override the old file)
http://wiki.xbmc.org/?title=RssFeeds.xml
Install new skin
apps
windows-filezilla
OSX - cyberduck
Change RSS feeds
