Full Version: Laggy Video Playback When Not On Default Brightness/Contrast
If I deviate from the default brightness or contrast settings (50), video playback for all files becomes extremely laggy, slowing down and then speeding up every couple of seconds, as well as causing the audio to desynch. This first appeared in SVN 15794 for me and is still a problem in 15807. The only way I've found to fix the problem (apart from leaving the brightness/contrast settings alone) is to set De-Interlacing to either Bob or Weave.
The problem does not occur in build 15765 (the only build I have prior to 15794) or any earlier build.
I've confirmed the issue on two separate machines:
Windows XP SP3
AMD 4850e X2
2GBs RAM
nVidia 8200
Windows XP SP3
Inter Core2 T8100
2GBs RAM
nVidia 8600M GT
Any ideas?
