OK, I've looked through the FAQ etc. but can't find any help.
I've downloaded the Mac version onto my Mac Mini but when I run the application all I get is a white blank box...any ideas?
Can anyone help a poor newb?
Please provide your Mac Mini's specification. In addition, please confirm that you installed Beta 2. Also, post the log file (~/Library/Logs/xbmc.log) to pastebin.com and provide the link here.
You're running Boxee, not XBMC. Either way, the reason for the failure is due to your OpenGL driver, it's running in software mode:
INFO: GL_RENDERER = Apple Software Renderer
Are you attempting this over remote desktop or something? I'm sure Boxee's tech support will be happy to help you out:
http://forum.boxee.tv/
EDIT: Let me add that the renderer string for an Intel Mac Mini should be something like:
INFO: GL_RENDERER = Intel GMA 950 OpenGL Engine
Well, I have downloaded both Boxee and XBMC, neither work. I may have been using Screen Sharing while launching XBMC, should I try without?
