Full Version: PM3.HD Now has Programs in home option
Ok I guess death buy a thousand cuts really does work.
Anyway I finally added a Option to show programs in the home menu of PM3.HD
Here is the Setting
Here is the default look
Image Image
Here is the option to change the background like the rest
And here it is with the pretty backgrounds from AEON
This will work its way down to the xbox version when the next merge happens ( Its currently in the linux port) so please don't bug me for when.
P.S. others feel free to upload complete compiled skin if you want
WOOOOOOP WOOOOOOP!!! Smile
Jezz your a STAR!!!
Thank goodness, now the kids will stop bugging me on how to load games...
Please please please someone upload Smile
Thanks you, Thank you, Thank you, Thank you. Now I really fell this skin is complete on the xbox. Legend, Thank you. Nod
Thanks, and thanks again for making it optional!
How does that pride taste Jezz_X? :p
I just got the updated pm3.hd from the SVN, uploaded it, and I am not seeing the new option to add programs to the main menu. What am I doing wrong?
its in system\skin settings then look at the first image I posted above
btw this is only in the linux svn still it hasn't made it to the xbox one yet
Jezz_X Wrote:its in system\skin settings then look at the first image I posted above
Not there.
I know that I have the latest version of xbmc for the xbox.
Then you probably didn't update properly.
https://xbmc.svn.sourceforge.net/svnroot/xbmc/branches/linuxport/XBMC/skin/PM3.HD
not the xbox one yet
Can I just send this batch of files to the xbox or do I have to do any more to it?
well you will need to make the textures.xpr but other than that its just the same
I got it working now, thanks.
I did notice once thing. In the little menu you get when you click the right stick, the option for the ms dashboard is labeled "XBMC" and the restart option has no label.
you need an updated strings.xml file as well from the linux branch
https://xbmc.svn.sourceforge.net/svnroot...trings.xml
