Full Version: Strange behaviour of MCE remote
I am testing XBMC Live with my MCE remote. It worked from beginning, but the "Play" button did not what it has to do.
Example 1:
If i am within a video or music list and want to play a title ... i expect that pressing the "ok" button or pressing the "play" button should start the track.
But only the "ok" button is working. The "play" button gives me something like an options menu.
Example 2:
I am playing a video or music file. I press "ffwd" button to seek forward. After seeking i wish to continue with normal play speed. I would expect that i have to press the "play" button to achive this, but it does not work. Instead the "pause" button does what i was expecting.
If press the "play" button during normal playing i get a info window which tells me something about the currently used codecs, the bitrate, .....
Is this normal? Or can i change this.
I read the XBMC Team likes to "keep it simple and self explaining". That is not the case concerning this issues.
But however, XBMC Live is a great idea and is working fine so far.
Thanks for all your work.
Plz guys,
no one here who can help me with this?
PLEASE, PLEASE
I have the same issue, although I haven't perused all the forum info yet. I am using the "old" MCE remote - http://ruel.net/pc/pvrpix/mce-remote.jpg
I can use the standard directional buttons, the OK button, and clear only. It would be really nice to have everything else working.
There was an older tutorial thread that involved installing a bunch of stuff. After doing all that, my remote didn't work at all.
I just found this thread: http://forum.xbmc.org/showthread.php?tid=38579 which might be worth a shot. Going to try it tonight and see how it does.
timhoeck Wrote:I just found this thread: http://forum.xbmc.org/showthread.php?tid=38579 which might be worth a shot. Going to try it tonight and see how it does.
This thread is mainly focused on windows. I think it would not help us here with XBMC Live
