Howdy folks,
I have been primarily using GB-PVR since getting my Hauppauge 1600, but after peeping some XBMC screenshots and drooling over my keyboard, I decided to give it a whirl. Most of the functionality worked right out of the box, and I am very impressed.
A few buttons on my remote worked with the default settings, but I decided to try to delve a little deeper in hopes of "getting it right." I added a section to the irremote.ini file (shown below), added a few lines to the Keymap.xml file, restarted the IR service, and restarted XBMC. Unfortunately, the settings aren't taking effect. I tested the irremote.ini configuration by copying the settings to a [Notepad] application and trying all the buttons while Notepad was running. This confirmed that the keys that I intended to be setup are configured correctly in the irremote.ini file.
If anyone here has had luck setting this up, I would sure appreciate a few pointers. Basic tasks, like escaping a menu, currently require keyboard input (which by the way works flawlessly). My only guess is that somehow XBMC is deciding that the commands sent via remote are not keypresses and that they are being interpreted as RC5 (or whatever) regardless of what I setup in the irremote.ini file.
Thanks in advance,
Achoo
From irremote.ini Wrote:[XBMC]
;Exit app
GRNPOWER=S
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
NAVDOWN={DOWN}
NAVUP={UP}
NAVRIGHT={right}
NAVLEFT={left}
CHNLUP={pgup}
CHNLDOWN={pgdn}
CHNLPREV={ctrl}W
SUBCC=t
VOLUP=+
VOLDOWN=-
YELLOW=z
GO=h
OK={enter}
RED=i
GREEN=o
FASTFWD=f
REWIND=r
BACK={esc}
SKIPFWD=.
MENU=c
PLAY=p
SKIPREV=,
PAUSE={space}
STOP=x
BLUE=\
REC={esc}
FUNC={ctrl}O
GUIDE=h
TVNEW=v
VIDEOS=v
MUSIC=n
PICTURES=p
RADIO={f6}
POWER=s
TEXT=m
go=h
from Keymap.xml Wrote:<keyboard>
<p>Play</p>
<q>Queue</q>
<f>FastForward</f>
<r>Rewind</r>
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
<pageup>PageUp</pageup>
<pagedown>PageDown</pagedown>
<return>Select</return>
<enter>Select</enter>
<backspace>ParentDir</backspace>
<m>ActivateWindow(PlayerControls)</m>
<s>ActivateWindow(shutdownmenu)</s>
<escape>PreviousMenu</escape>
<i>Info</i>
<menu>ContextMenu</menu>
<c>ContextMenu</c>
<space>Pause</space>
<x>Stop</x>
<period>SkipNext</period>
<comma>SkipPrevious</comma>
<tab>FullScreen</tab>
<printscreen>Screenshot</printscreen>
<minus>VolumeDown</minus>
<plus>VolumeUp</plus>
<zero>Number0</zero>
<one>Number1</one>
<two>Number2</two>
<three>Number3</three>
<four>Number4</four>
<five>Number5</five>
<six>Number6</six>
<seven>Number7</seven>
<eight>Number8</eight>
<nine>Number9</nine>
<backslash>ToggleFullScreen</backslash>
<h>XBMC.ActivateWindow(Home)</h>
<n>XBMC.ActivateWindow(MyMusic)</n>
<p>XBMC.ActivateWindow(pictures)</p>
<v>XBMC.ActivateWindow(video)</v>
<browser_home>XBMC.ActivateWindow(Home)</browser_home>
<browser_favorites>ActivateWindow(Favourites)</browser_favorites>
<browser_refresh></browser_refresh>
<browser_search></browser_search>
<launch_app1_pc_icon>ActivateWindow(MyPrograms)</launch_app1_pc_icon>
<launch_media_select>XBMC.ActivateWindow(MyMusic)</launch_media_select>
<play_pause>Pause</play_pause>
<stop>Stop</stop>
<volume_up>VolumeUp</volume_up>
<volume_mute>Mute</volume_mute>
<volume_down>VolumeDown</volume_down>
<next_track>SkipNext</next_track>
<prev_track>SkipPrevious</prev_track>
<launch_mail></launch_mail>
<key id="61620"></key> <!-- same as above, launch_mail, but using button code (based on vkey id) -->
<end>XBMC.ShutDown()</end>
</keyboard>
</global>
heres my irremote.ini, works a treat for both VMC and XBMC. the go button launches XBMC.bat in C:\Program Files\XBMC which I created to launch XBMC with the -fs -p parameters. The Green power button launches VMC. Different mappings take focus dependent on which application is in use.
; FGR 06/03/2008 Support firmware V2; 32-bit IR application
; FILEVERSION 2,58,26155,0
; includes support for both Classic black, Silver PVR remote, and new extended Remote
; (extended remote has Music/Videos/Pictures and seperate NAV buttons among others)
; requires ir32.exe, irremote.dll 2.45.22230 or later
; Supports Key Codes 64-127 via RC5 'field' bit
; support latest IR HW on WinTV-USB2, and "IR Blaster" RC5/RC6 receiver
; adds support for retail apps to work with MS MCE "beanbag" Remote on non-MCE systems
; adds support for HCWHID custom interface
; adds support for MCE2005/Vista application
; adds support for WinTV6 app
; fix support for WinTV6 - Findwnd(WinTV_32,wintv) vs Findwnd(WinTV_32,wintv32)
; add support for GT6000 IR
; Add support for 885/887 based cards; update some MCE remote mappings
; Add support for Sceneo
; Add support for IRCLASS based IR capture (Wiltshire/Halesite/Medford2/Kingston2)
; Allow use of MCE remotes by default (on HW that supports RC6)
[Remote]
RepeatDelay=3
;Beep = 1 ; Sound for MessageBeep() to make for each Remote Keystroke
;PowerDownSound = 0 ; Sound for MessageBeep() to make when powering down
MenuLoad=2 ; use tray as app launcher
; map RC5 System Codes to button "name" lookup table
; Note: 0 (classic remote) conflicts with standard "philips" TV remotes
[SystemCode]
0=HCWClassic
29=HCWPVR2
30=HCWPVR2
31=HCWPVR
; "IR Blaster" and 885/887 HW can support RC6; this is for the MS MCE remote table if desired
0x800f=MSMCE
; This supports using the MCE "Beanbag" remote with retail apps on non-MCE systems
0xffbc=MSMCERCV
0x2040=HCWPVR2
; these tables map actual IR scan codes to button "names" on a per system code basis
; Undefined values get the name "CODExx" by default (mostly for debugging)
; Real buttons on a remote should always get a real button name
; Note: some button "names" can only be generated by certain remotes
; Also, note that seemingly similar buttons may have unique names on different remotes
; This is to allow treating them differently based on the remote, and the
; "paradigm" of how they are used. For example; on old remotes there is a seperate TV
; button, but no GRNPOWER button. So, on old remotes we treat TV as on/off, where on PVR
; remote we use the GoMenu function (or RED as On), and the GRNPOWER as Off.
[HCWClassic]
; need to differentiate old '0' from newer remotes; Old 0 was also labled "pause"
0=OLD0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
12=RADIO
13=MUTE
15=TV
16=VOLUP
17=VOLDOWN
30=RESERVED
32=CHNLUP
33=CHNLDOWN
34=SOURCE
38=MINIMIZE
46=FULLSCREEN
[HCWPVR]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
12=FUNC
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
60=FULLSCREEN
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
[HCWPVR2]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
;new to hcwpvr2
12=RADIO
28=TVNEW
24=VIDEOS
25=MUSIC
26=PICTURES
27=GUIDE
22=NAVLEFT
23=NAVRIGHT
20=NAVUP
21=NAVDOWN
10=TEXT
14=SUBCC
18=CHNLPREV
[MSMCE]
12=GRNPOWER
23=REC
25=STOP
24=PAUSE
22=PLAY
21=REWIND
20=FASTFWD
26=SKIPFWD
27=SKIPREV
13=MCEJEWEL
35=BACK
38=GUIDE
32=NAVLEFT
33=NAVRIGHT
30=NAVUP
31=NAVDOWN
34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TVNEW
14=MUTE
16=VOLUP
17=VOLDOWN
18=CHNLUP
19=CHNLDOWN
36=DVDMENU
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
10=CLEAR
11=ENTER
78=PRINT
72=RECORDEDTV
28=MCEPOUND
29=MCESTAR
128=MCE128
129=MCE129
90=TEXT
91=RED
92=GREEN
93=YELLOW
94=BLUE
15=MCEINFO
; by default the MS Beanbag sends most keys as either keyboard chars or APP_COMMANDS already
; so we only handle the "special" buttons
[MSMCERCV]
12=GRNPOWER
;23=REC
;25=STOP
;24=PAUSE
;22=PLAY
;21=REWIND
;20=FASTFWD
;26=SKIPFWD
;27=SKIPREV
13=MCEJEWEL
;35=BACK
38=GUIDE
;32=NAVLEFT
;33=NAVRIGHT
;30=NAVUP
;31=NAVDOWN
;34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TVNEW
;14=MUTE
;16=VOLUP
;17=VOLDOWN
;18=CHNLUP
;19=CHNLDOWN
36=DVDMENU
;0=0
;1=1
;2=2
;3=3
;4=4
;5=5
;6=6
;7=7
;8=8
;9=9
;10=CLEAR
;11=ENTER
78=PRINT
72=RECORDEDTV
28=MCEPOUND
29=MCESTAR
126=MCE128
127=MCE129
90=TEXT
91=RED
92=GREEN
93=YELLOW
94=BLUE
; First item in this section IS always the default app if no others found
[Applications]
Default=
XBMC=
Media Center=
[Default]
OLD0=
0=
1=
2=
3=
4=
5=
6=
7=
8=
9=
NAVUP={UP}
NAVDOWN={DOWN}
NAVLEFT={left}
NAVRIGHT={right}
OK={enter}
BACK={backspace}
MENU={esc}
GRNPOWER={run(C:\windows\ehome\ehshell.exe)}
MCEJEWEL={run(C:\windows\ehome\ehshell.exe)}
GUIDE=={ALT}{F4}
GO={run(C:\progra~1\xbmc\xbmc.bat)}
MENU={switch(*task*)}{shift}{tab}
RED=
GREEN=
YELLOW=
BLUE=
TEXT=
;;default mappings to drive apps that use APPCOMMANDS on Win2000/XP
MUTE={app(0x80000)}
CHNLUP={app(0x330000)}
CHNLDOWN={app(0x340000)}
VOLUP={app(0xa0000)}
VOLDOWN={app(0x90000)}
REC={app(0x300000)}
STOP={app(0xd0000)}
PAUSE={app(0x2f0000)}
PLAY={app(0x2e0000)}
REWIND={app(0x320000)}
FASTFWD={app(0x310000)}
SKIPFWD={app(0xb0000)}
SKIPREV={app(0xc0000)}
[Media Center]
;Exit app
GRNPOWER={ALT}{F4}
;Main MCE menu
GO={ALT}{HOME}
MCEJEWEL={ALT}{HOME}
TV={CTRL}t
TVNEW={CTRL}t
VIDEOS={CTRL}e
MUSIC={CTRL}m
PICTURES={CTRL}i
GUIDE={CTRL}g
RADIO={CTRL}a
BACK={backspace}
MENU={apps}
NAVDOWN={down}
NAVLEFT={left}
NAVRIGHT={right}
NAVUP={up}
OK={enter}
REC={Ctrl}r
PLAY={Ctrl}{shift}p
PAUSE={Ctrl}p
STOP={Ctrl}{shift}s
REWIND={Ctrl}{shift}b
FASTFWD={Ctrl}{shift}f
SKIPREV={Ctrl}b
SKIPFWD={Ctrl}f
MUTE={F8}
VOLUP={F10}
VOLDOWN={F9}
CHNLUP={pgup}
CHNLDOWN={pgdn}
;toggle full screen
CHNLPREV={alt}{enter}
FULLSCREEN={alt}{enter}
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
;Change the DVD subtitles selection
TEXT={ctrl}u
;Closed Captions On/Off
SUBCC={ctrl}{shift}c
;DVD Menu
GREEN={ctrl}{shift}m
;Recorded TV
RED={ctrl}{shift}t
;Change the DVD audio selection
YELLOW={ctrl}{shift}a
;toggle full screen
BLUE={alt}{enter}
[XBMC]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
GUIDE=o
GO={home}
NAVUP={UP}
NAVDOWN={DOWN}
NAVLEFT={left}
NAVRIGHT={right}
OK={enter}
BACK={esc}
MENU=i
VOLUP=+
VOLDOWN=-
MUTE={tab}
CHNLUP={pgup}
CHNLDOWN={pgdn}
CHNLPREV=i
REC=r
STOP=x
PAUSE={space}
PLAY=p
REWIND=r
FASTFWD=f
SKIPFWD=.
SKIPREV=,
RED={alt}{tab}
RADIO=c
PICTURES={backspace}
Thank you for the speedy response, Dave. My irremote is almost identical to yours, and I'm afraid that trying yours yielded no better results for me. I currently have a line in my irremote that looks like this:
launch XBMC and move it to the foregrount Wrote:GO={run(C:\Progra~1\XBMC\XBMC.exe -fs -p)}{sleep(2000)}{findwnd(,xbmc)}{fgnwnd()}
, which launches XBMC and moves it to the foreground when I press the GO button. My irremote changes work for all my other apps, but for whatever reason XBMC is not seeing the changes.
Thank you for sharing, and I would welcome any other advice you can proffer.
Your friend,
Achoo
daveUK Wrote:heres my irremote.ini, works a treat for both VMC and XBMC. the go button launches XBMC.bat in C:\Program Files\XBMC which I created to launch XBMC with the -fs -p parameters. The Green power button launches VMC. Different mappings take focus dependent on which application is in use.Code:
[Remote]
RepeatDelay=3
[SystemCode]
0=HCWClassic
29=HCWPVR2
30=HCWPVR2
31=HCWPVR
0x800f=MSMCE
0xffbc=MSMCERCV
0x2040=HCWPVR2
[HCWClassic]
0=OLD0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
12=RADIO
13=MUTE
15=TV
16=VOLUP
17=VOLDOWN
30=RESERVED
32=CHNLUP
33=CHNLDOWN
34=SOURCE
38=MINIMIZE
46=FULLSCREEN
[HCWPVR]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
12=FUNC
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
60=FULLSCREEN
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
[HCWPVR2]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
;new to hcwpvr2
12=RADIO
28=TVNEW
24=VIDEOS
25=MUSIC
26=PICTURES
27=GUIDE
22=NAVLEFT
23=NAVRIGHT
20=NAVUP
21=NAVDOWN
10=TEXT
14=SUBCC
18=CHNLPREV
[MSMCE]
12=GRNPOWER
23=REC
25=STOP
24=PAUSE
22=PLAY
21=REWIND
20=FASTFWD
26=SKIPFWD
27=SKIPREV
13=MCEJEWEL
35=BACK
38=GUIDE
32=NAVLEFT
33=NAVRIGHT
30=NAVUP
31=NAVDOWN
34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TVNEW
14=MUTE
16=VOLUP
17=VOLDOWN
18=CHNLUP
19=CHNLDOWN
36=DVDMENU
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
10=CLEAR
11=ENTER
78=PRINT
72=RECORDEDTV
28=MCEPOUND
29=MCESTAR
128=MCE128
129=MCE129
90=TEXT
91=RED
92=GREEN
93=YELLOW
94=BLUE
15=MCEINFO
[MSMCERCV]
12=GRNPOWER
;23=REC
;25=STOP
;24=PAUSE
;22=PLAY
;21=REWIND
;20=FASTFWD
;26=SKIPFWD
;27=SKIPREV
13=MCEJEWEL
;35=BACK
38=GUIDE
;32=NAVLEFT
;33=NAVRIGHT
;30=NAVUP
;31=NAVDOWN
;34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TVNEW
;14=MUTE
;16=VOLUP
;17=VOLDOWN
;18=CHNLUP
;19=CHNLDOWN
36=DVDMENU
;0=0
;1=1
;2=2
;3=3
;4=4
;5=5
;6=6
;7=7
;8=8
;9=9
;10=CLEAR
;11=ENTER
78=PRINT
72=RECORDEDTV
28=MCEPOUND
29=MCESTAR
126=MCE128
127=MCE129
90=TEXT
91=RED
92=GREEN
93=YELLOW
94=BLUE
[Applications]
Default=
XBMC=
Media Center=
[Default]
OLD0=
0=
1=
2=
3=
4=
5=
6=
7=
8=
9=
NAVUP={UP}
NAVDOWN={DOWN}
NAVLEFT={left}
NAVRIGHT={right}
OK={enter}
BACK={backspace}
MENU={esc}
GUIDE=={ALT}{F4}
RED=
GREEN=
YELLOW=
BLUE=
TEXT=
MUTE={app(0x80000)}
REC={app(0x300000)}
STOP={app(0xd0000)}
[Media Center]
;Exit app
GRNPOWER={ALT}{F4}
;Main MCE menu
GO={ALT}{HOME}
TV={CTRL}t
TVNEW={CTRL}t
VIDEOS={CTRL}e
MUSIC={CTRL}m
PICTURES={CTRL}i
GUIDE={CTRL}g
RADIO={CTRL}a
BACK={backspace}
MENU={apps}
NAVDOWN={down}
NAVLEFT={left}
NAVRIGHT={right}
NAVUP={up}
OK={enter}
REC={Ctrl}r
PLAY={Ctrl}{shift}p
PAUSE={Ctrl}p
STOP={Ctrl}{shift}s
SKIPREV={Ctrl}b
SKIPFWD={Ctrl}f
MUTE={F8}
VOLUP={F10}
VOLDOWN={F9}
CHNLUP={pgup}
CHNLDOWN={pgdn}
;toggle full screen
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
TEXT={ctrl}u
;DVD Menu
;Recorded TV
RED={ctrl}{shift}t
;toggle full screen
BLUE={alt}{enter}
[XBMC]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
GUIDE=o
GO={home}
NAVUP={UP}
NAVDOWN={DOWN}
NAVLEFT={left}
NAVRIGHT={right}
OK={enter}
BACK={esc}
MENU=i
VOLUP=+
VOLDOWN=-
MUTE={tab}
CHNLUP={pgup}
CHNLDOWN={pgdn}
CHNLPREV=i
REC=r
STOP=x
PAUSE={space}
PLAY=p
REWIND=r
FASTFWD=f
SKIPFWD=.
SKIPREV=,
RED={alt}{tab}
RADIO=c
All i can do is tell you a little bit more about my set up as it just works for me.
I'm running Vista Ultimate 32, XBMC beta2 with the default keymap.xml, my tuner card is the NOVA-HD-S2, the remote is the 45 button one and i have the drivers and winTV app installed from WinTV CD 4.6b
Remember that every time you change the irremote.ini file you need to restart the remote application. Then the buttons should work. Sometimes I forget when changing commands.
I just added the following:
to mine yesterday(different keyboard commands). I even setup a button to launch Beyond TV. I love this remote program.
Add a section to the top of irremote.ini that just says
XBMC=
under the [Applications] section
