i am running the latest beta on my 10.4.11 mac and everything is working great, but i have one question, can i control it by using my USB-360 controller?
I'm not familiar with the USB-360, could you provide a link to it. If OS X detects the device as a regular joystick then you should be able to add a keymap for it.
would be cool if you could use wii controllor on appletv running xbmc
I believe the 360 support is enabled out of the box. Try enabling Apple remote support (settings->system->apple remote) and see if that helps.
tried enableing Apple Remote (tried Univerals and standard) but nothing changes... the controller is working in other Programs (like, zsnes, mame, etc) but i still cant control xbmc with it.
