2008-10-14, 03:04
2008-10-14, 10:30
Does ffmpeg support them? That's the question, the only question one should ask himself when it comes to XBMC and codecs.
2008-10-14, 20:02
spdif and coax does not support them. do you have hdmi 1.3 audio out for starters?
2008-10-14, 20:39
i don't know which version of hdmi output i have on my laptop. its a asus/ velocity micro c90. but i guess it won't work anyway because im using spdif.
2008-10-14, 21:59
As far as I know there's only one card on the market right now that can bitstream the new Dolby/DTS audio formats over HDMI. That's Asus HDAV1.3.
However, a protected audio path (PAP) is required between the software and the hardware to fulfill the requirements of the AACS. The most viable solution will probably be to wait for codec support in ffmpeg, then we can use ffmpeg and pass 7.1 LPCM over HDMI. This is supported by many newer video cards.
-Eicar
-Eicar
2008-10-14, 22:54
thanks
2008-10-15, 02:54
I've seen an ffmpeg truehd patch floating around the web, do you thnk that it would work?
"Also, FFmpeg now has floating point PCM support and supports MLP/TrueHD decoding (FFmpeg SoC 2008 should bring us an encoder), Apple Lossless Audio encoding (FFmpeg SoC 2008) MVI demuxing and Motion Pixels Video decoding, D-Cinema audio muxing, Electronic Arts CMV and TGV decoding and MAXIS EA XA demuxing/decoding. "
http://ffmpeg.mplayerhq.hu/
2008-10-15, 02:57
mean because the new 8200/8300 nvidia boards do pass 7 channel pcm through it's hdmi. Also, when the Asus HDAV1.3 come out we will have the PAP needed, right?
I'm just throwing things that are new that i haven't seen addressed to ths question before.
I've seen this question a bunch but I have never seen the new decoder, new hdmi boards, and new hdmi sound card addressed.
2008-10-15, 11:15
dts hd is partly supported in xbmc on linux/windows atleast. it will decode/passthrough as if it was standard dts.
ac3 hd aka truehd will be mostly supported when we update our ffmpeg libs. (won't be before we release).
2008-10-15, 18:58
Keep an eye on:
http://wiki.multimedia.cx/index.php?titl...ER_OF_CODE
Read this why:
http://wiki.xbmc.org/?title=Codec_and_Format_requests
...also remember that we are in a feature freeze until Atlantis 'Gold' (Final) have been released
Read this why:
2008-10-15, 19:21
primary objective will be:
decode new HD audio formats to multichannel LPCM
and then either
a) Output LPCM over HDMI
b) re-encode to AC3/DTS for SPDIF output
and then either
2008-10-15, 22:27
can I suggest
c) output over 6channel analog to a recievers 6channel analog inputs
for those of us without the luxury of an HDMI capable amp
pretty please.
pretty please.
2008-10-16, 03:13
decoding to lpcm would definitely be the way to go then people without hdmi amps and people with can benefit.
hell, that's what they did with the ps3 and I can still get HD sound with a receiver that doesn't do the bitstream hd audios.
2008-10-16, 16:34
Those are separate requests, see:
http://trac.xbmc.org/ticket/4871 / http://forum.xbmc.org/showthread.php?tid=36982
and:
http://trac.xbmc.org/ticket/4450
and:
2008-11-25, 05:25
ok thanks
