Full Version: Apple TV/XBMC picture quality problems
Something's up with the AVI and MP4 files played in XBMC. There's a distinctive misalignment, basically a fraction of a second lag between the top half and bottom half of the screen, whenever something on screen is in motion (everything looks fine in static/paused position). I've played the same content on my ATV (sans XBMC), and there's no such issue. I had this problem when I'd first set things up with my Apple TV set to 1080p (the highest resolution available on my TV). I had a hunch that was the culprit, so I bumped ATV down to 720p, and voila, problem solved. Now however, with that same setting, the issue's returned. Any ideas?
Do you have vsync enabled?
Not sure, where would I find that option?
Settings->Appearance->Screen. It should be set to "Always Enabled" for apple tv + OS X.
That did it! Thanks a million.
