I cant figure out why mediastream does this. In PM3.HD i can suspend and come back without any problems, but in mediastream it will suspend but when i start up the computer instantly it will show the little window telling me that its going to suspend.It keeps going like that it will never come out of suspend when i use PM3.HD it works fine any ideas how to fix this ?
hmm i thought maybe beta 2 would fix my problem but now even PM3.HD does this.
am i the only one with this problem? i tried to search to see if i cant find a topic but i couldn't
here is some log from the point where it starts to do this
05:26:38 T:1804 M:1600794624 INFO: Loading skin file: DialogButtonMenu.xml
05:26:38 T:1804 M:1600778240 DEBUG: Load DialogButtonMenu.xml: 20.11ms
05:26:38 T:1804 M:1584304128 DEBUG: Alloc resources: 486.39ms (20.19 ms skin load, 1.66 ms preload)
05:26:40 T:1804 M:1580908544 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
05:26:40 T:1804 M:1586872320 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
05:26:41 T:1804 M:1587597312 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
05:26:42 T:1804 M:1587761152 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
05:26:42 T:1804 M:1588604928 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
05:26:43 T:1804 M:1589125120 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
05:26:43 T:1804 M:1589100544 DEBUG: CApplication::OnMessage : Translating XBMC.ShutDown()
05:26:43 T:1804 M:1589096448 DEBUG: CApplication::OnMessage : To XBMC.ShutDown()
05:26:43 T:1804 M:1589104640 INFO: Asking Windows to suspend...
05:27:10 T:1804 M:1606860800 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
05:27:10 T:1804 M:1606836224 DEBUG: CApplication::OnMessage : Translating ActivateWindow(ShutdownMenu)
05:27:10 T:1804 M:1606836224 DEBUG: CApplication::OnMessage : To ActivateWindow(ShutdownMenu)
05:27:10 T:1804 M:1606836224 DEBUG: Activating window ID: 10111
05:27:10 T:1804 M:1606836224 DEBUG: Checking if window ID 10111 is locked.
05:27:10 T:1804 M:1606836224 INFO: Loading skin file: DialogButtonMenu.xml
05:27:10 T:1804 M:1606877184 DEBUG: Load DialogButtonMenu.xml: 7.61ms
05:27:10 T:1804 M:1595846656 DEBUG: Alloc resources: 554.71ms (7.69 ms skin load, 1.98 ms preload)
05:27:10 T:1804 M:1595846656 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
05:27:10 T:1804 M:1595822080 DEBUG: CApplication::OnMessage : Translating XBMC.ShutDown()
05:27:10 T:1804 M:1595822080 DEBUG: CApplication::OnMessage : To XBMC.ShutDown()
05:27:10 T:1804 M:1604509696 INFO: Asking Windows to suspend...
05:27:23 T:1804 M:1605124096 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
05:27:23 T:1804 M:1604993024 DEBUG: CApplication::OnMessage : Translating ActivateWindow(ShutdownMenu)
05:27:23 T:1804 M:1604993024 DEBUG: CApplication::OnMessage : To ActivateWindow(ShutdownMenu)
05:27:23 T:1804 M:1604993024 DEBUG: Activating window ID: 10111
05:27:23 T:1804 M:1604993024 DEBUG: Checking if window ID 10111 is locked.
05:27:23 T:1804 M:1604993024 INFO: Loading skin file: DialogButtonMenu.xml
05:27:23 T:1804 M:1604550656 DEBUG: Load DialogButtonMenu.xml: 16.56ms
05:27:30 T:1804 M:1597026304 DEBUG: Alloc resources: 6664.52ms (16.64 ms skin load, 2.52 ms preload)
05:27:30 T:1804 M:1597026304 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
05:27:30 T:1804 M:1597001728 DEBUG: CApplication::OnMessage : Translating XBMC.ShutDown()
05:27:30 T:1804 M:1597001728 DEBUG: CApplication::OnMessage : To XBMC.ShutDown()
05:27:30 T:1804 M:1598668800 INFO: Asking Windows to suspend...
