2008-10-17, 19:16
Hi All,
please can we define the best and cheapest working solution
motherboard
for a HD videoplayer with XBMC Live USB stick or
XBMC Live SSD harddisk or CompactFlash to IDE adpater installation
which is also small and has integrated graphics
onboard with HDMI outputs ?
I have looked up a few new MiniITX motherboards and the
best one in this moment seems to be the new
780G chipset based ones like :
http://www.jwele.com/motherboard_detail.php?419
for instance.
As I want to have a small PC which fits into a small case and can
be plugged via HDMI to my LCD TV and I also want to play
a 3D game sometimes, I guess this motherboard is a good solution,
although it is still pretty expensive.
What about the new Atom 330 based motherboards ?
Is there already one with HDMI or DVI outputs ?
The standard Intel Atom 330 motherboard has only
got VGA and S-Video output, but no DVI or HDMI...
Also the integrated graphics is not fast enough for 3D gaming.
So what will be the best solution to fit inside a MiniITX case.
What other MiniITX solutions will you go for and what motherboards
are already 100 % compatibe with the current Beta2 Live solution ?
Many thanks.
motherboard
for instance.
Many thanks.
