Full Version: Error loading jpeg - no SOI marker found in first 4096 bytes
As the title says, not able to view (larger) pictures.... Here are some details:
- Seems to be only with larger pictures (2.5Mb+)/Highres, smaller show fine
- All thumbnails are created correctly and show fine
- Logfile only says as the title shows
- Pictures are on a samba (Linux) share (Wireless connection)
- Only shows complete black screen, need to press 'menu' _twice_ to get back to picturelist
- ATV 2.2
- XBMC B2
- Launcher 0.4
Did some searching and found that 'JMarshall' worked on this 'bug' a while ago and tagged it 'fixed'... ( http://forum.xbmc.org/showthread.php?tid=36272 )
Appreciate any help.
TIA!
That's not necessarily a problem - it just means it's not a valid JPEG file. Since the thumbs are created fine, it has no problem reading the image - the problem is on the display side.
d4rk popped a couple of fixes in today for exactly this, so the next version should be all good - you're more than welcome to do up a build yourself if you wish, else await the next release, which should be out in the next week or so.
Cheers,
Jonathan
Many thanks! I'll await the next version.
