What about the Vista Remote controller. (its not the same as the MCE Remote!). My Vista remote is working with the arrow buttons, and the middle button in XBMC. But not the rest of my buttons. Can somebody write a tutorial or something about the VMC Remote under Vista OS?
Have the same problem...
Initially I thought I was having vista 64 bit problems with event ghost. But it would appear that this was not the issue, as 64bit mce drivers have been released.
A note you may find usefull which was bugging me when using the vista remote is that the key "0" will act as an escape key (back button) so this will get you out of some of the windows you normally have to get up and press the escape key on your keyboard for.
I'm using the newest beta build of EventGhost, XBMC plugin for it, and MCE remote plugin... on vista 32bit... is working find for me...
Are you using the latest beta build of EG?
http://eventghost.org/downloads/
I couldn't get it to work before either, but recently support was added for it... not sure which build tho...
