Full Version: Skin edit help for a noob
oooo tay its my first post... Just found out xbmc is available on windows so been playing around with it all day...
I really like Aeon Showcase view, though I would like to tinker around with some things if someone could show me at least where to look...
I would be interested in performing 1 or more of the following to Showcase...
1. Reduce the size of the DVD covers (both non selected and selected)...
2. Remove the mirror effect at the bottom.
3. Remove/move the Title/genre at the bottom
4. lower the DVD posters closer to the bottom...
I have been dinking around in the includes.xml but seem to be 0 for 10 so far?
Am I in the right place or is there another XML that handles size and locations of these objects? I tried looking in Myvideo.xml but didn't really find much searching via the obvious object names aka genre or title...
All I really am looking for is the correct file name(s) and maybe a object or include name to search for, I am more then willing to do tons of trial and error...
You'll want to look in FullscreenViews.xml. The include name is Viewtype_Showcase. Good luck.
Thanks for the pointer!!!!
You might also want to check out the Horizonz mod to this skin as well. It adds a new "Info" view that sounds more like what you're looking for. It also fixes a lot of the loose ends that didn't quite get finished up in Aeon before djh got pulled away on his new Stark idea.
