Full Version: [Apple TV] playback info
Is there any way to get play back info of a video on the AppleTV? I'm testing some encodes and I'd like to know if the atv is dropping frames and how much cpu is being used. But, with the limited buttons on the atv remote, I don't know what to do. I have a Harmony remote that is progamming with the old Xbox I XBMC codes, but they don't work either.
thanks.
rcrh Wrote:Is there any way to get play back info of a video on the AppleTV? I'm testing some encodes and I'd like to know if the atv is dropping frames and how much cpu is being used. But, with the limited buttons on the atv remote, I don't know what to do. I have a Harmony remote that is progamming with the old Xbox I XBMC codes, but they don't work either.
thanks.
It should work to modify /Applications/XBMC.app/Contents/Resources/XBMC/system/Keymap.xml
or ~/Library/Application Support/XBMC/userdata for your needs.
Harmony / Universal Remote support is still a pending issue....
wow, the keymap.xml is complicated. I think I'll just sit back & wait for harmony support to come thru a future release. Too bad, cause I've also found that I want to use one of the skins that isn't quite as memory intensive. But, PMIII doesn't have a STOP button on the video OSD.
