Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Hi Wir3d,
me again, found what i think is a bug in the file manager view (xbox, atlantis, PAL 4x3). When I use the context menu on a folder and select "calculate size" it seems to do something but the folder size doesn't show up.
Any ideas?
DrEaD Wrote:do you tell me how put startup playlist?
You should probably ask the skinner to add this feature. It would be very difficult for me to explain it.
cromity123 Wrote:Hi Wir3d,
Any ideas?
I found the issue and it will be resolved soon (hopefully tomorrow).
Thanks for pointing it out.
Revision 1871 is up with several fixes and updates.
no more updates?
I have been doing a ton of optimizing over the last couple weeks.
Should see something real soon.
Very nice skin!
Any updates?
Still cleaning up. All changes are currently in SVN.
Is there something specific you are looking for?
Totally missed this skin! Those screenies look promising, so gonna check this asap. Thanks for sharing!
Revision 1906 added to first post.
No large changes. Just allot of code cleanup.
Wir3d Wrote:Is there something specific you are looking for?
Just couple suggestions:
1.Option to use bigger (much bigger) fonts in all screens (home screen is fine).
2.DVDthumb or Coverflow view in file mode.
3. Video on background when exiting 'full screen video' (currently small window appears only in home screen) and I think we don't need info window popup at this point.
igsolt Wrote:Just couple suggestions:
What resolution are you referring to needing larger fonts?
Can we have more screenshoot please ?
Is there an option to stop this?
First I go to: Videos>TV Shows> 30 Rock, and Scroll to Stargate Atlantis
When I exit back to home screen and then choose to go to TV Shows again It defaults back to 30 Rock instead of where i left it at Stargate Atlantis ...
XBMCG33K Wrote:Is there an option to stop this?
The TV Shows shortcut is set for tvshowtitles.
If you want it to work like PMIII you need to disable the Videos Submenu.
