I didn't create a Profile but I did tweak several XBMC settings and somehow I turned on the "Logon as the Master User" screen to appear during start. How do I turn this off?
by turning off the option
it depends on your skin, but in general you'll find it in the 'profiles' section of the settings.
I think I need to change the skin, I might see the Profiles option then. Thanks, I'll update this in the evening.
Yep, apparently I couldn't locate the Profiles in the MediaStream skin. I was able to turn this off after changing the skin.
