Love this skin but where do I see what version of the skin I currently use?
TIA!
There's nothing in the skin (yet) that shows the version number but if you check the changehistory.txt file in the MediaStream folder you should be able to work it out
Thanks Nuka, updated our build.bat to do something similar and the revision no. details will now show in the System Info screen from the next release
