I've configured my LastFM username/password in settings and when I go into Music from the main menu I can choose LastFM and see my favourite artists, etc so my username/password must be correct.
However, when I choose any of the 'Listen xxx' options I don't get any music. Shoutcast works and everything else but not LastFM.
What am I doing wrong?
What version are you using? I'm listening to last.fm right now from XBMC Atlantis beta 2 on xbox. I can't remember the last time it was broken so if you're using beta 2 (or more recent if available by the time you read this) you'll need to pastebin a debug log.
I have a question about last.fm that is similar to orig posters issue:
I can see my profile on xbmc, how do I just play my library? when trying to play radio nothing happens. Will get debug log once I get back home.
Quote:18:59:39 M: 27619328 INFO: Get URL: http://ws.audioscrobbler.com/radio/hands...0&partner=
18:59:39 M: 27619328 DEBUG: Parameter session -> FAILED
18:59:39 M: 27619328 DEBUG: Parameter base_url ->
18:59:39 M: 27619328 DEBUG: Parameter base_path ->
18:59:39 M: 27619328 DEBUG: Parameter subscriber ->
18:59:39 M: 27619328 DEBUG: Parameter banned ->
18:59:39 M: 27619328 ERROR: Last.fm return failed response, possible bad username or password?
You sure your credentials are correct? Try reentering them and check guisettings.xml with a text editor. Also, just for fun, try with the PM3 skin (not PM3HD).
will check again.
I assumed it was all correct since I can browse my artist and profile information.
ok, apparently even with a bad password you can view your profile and associated information.
case closed. problem in chair not in computer.
