2008-10-29, 17:58
So I've now run XBMC under several flavors of Ubuntu, as well as Mint Linux (where I'm at now), with 3 different graphics solutions.
I was using the a built in Intel GMA 3100 with HDMI out, then moved to an old GeForce 7300 GT via DVI to HDMI adaptor, and finally got a new Radeon HD 3450, also using DVI to HDMI adaptor.
The two constants have been XBMC and my screen and resolution.
I'm using an Olevia 32" LCD, running at the native 1360 by 768 resolution @ 60 Hz. Please note this is my desktop resolution for both Windows XP and Linux and that playing the same content using other things like Kaffeine and VLC results in perfect output.
in XBMC, whenever stuff is moving horizontally across the frame, it seems to "tear" around the middle of the frame, like the upper half and lower half of the screen are slightly off. I've played around with the settings but don't really know what I'm looking for.
Some sort of interlace handling issue? I'm sure this is some stupid settings issue because like I said, other software doesn't have this problem so I know the hardware is OK.
