Full Version: "No scanned information for this view, switch to the Files view"
Just bought the ATV patchstick and it works like a charm. I used to have ATVPAtch...and you all know how that worked out :oops:
First of all I want to give a big Props to XBMX?BOXEE and the ATVFlash team for putting out such a good product.
Now that said I like to share a problem with you and I hope you can help me out... My question is how can I add the media library that I use for NitoTv (Movies)to my XBMC? If I go to movies I get the following message "No scanned information for this view, switch to the Files view" In the files view I can select the movies and play them. But because I like a slick Media center I would love to know How I can get the view with the Thumbnails (enabled it in preferences)....
The second question is, about the music...I've got the same message.....where is the Music been stored on the ATV? Can I link to it?
I hope someone can help me out...All help is very much appreciated!!!
PS for the record:
I enabled Thumbnails in Preferences and Update when starting XBMC, but nothing
You have to add them to the library. In files mode go to the directory where your files are and press and hold Menu and you will figure out the rest yourself.
PS. I suggest you naming your directories in a correct way (i.e. TV/Heroes/ ... or TV/Heroes/Season1/ ... and avoid names like TV/Heroes.Full.Season.1.HDTV.LOL.720P/ ... ). If you use shitty names for your directories the scrapper will fail identifying the program and you will have to inform the name manually via the remote. I figured out this after wasting a couple of hours.
Thanks! Got the videos working! Just have to figure the music out...hope that it will work...
