Full Version: Get back to playing now
Ok so I think I got everything working as it should on my appletv. Got the overscan right and all... Still struggling with the remote.... How do you get back to playing now after you press menu during video play back. I see the controls on the butom of each screen, but I cant get to them. Press and Hold menu button and getting the menu(context menu I assume) has the playing now option, but when I get to it, it shows me the file I click it and it starts to reload the file again..... Also wasnt there a way to delete files/folders from XBMC on SMB shares.... I remmber doing that on my XBOX, now I dont see that option when I press and hold menu on a folder/file....
Thanks for the greatest media center ever !!!!!!!
This depends on the skin, I think. Try pressing and holding PLAY.
Hmm will try that. I`m using the default skin.
Yep worked. Just hold the play button Smile
Wonder why atv is a bit slow after wake up from standby, xbmc seems to be crawling after wake up .....
