Full Version: importing itunes library does not seem to work
hello
i just installed xbmc/boxee on my apple tv. i also installed the latest atlantis beta 2 build.
when i try to import my itunes library, i get a green pop-up window that says something like "importing - 0 items importet".
shouldn't this just work with itunes "out of the box" ? or maybe i'm overlooking something ?
thanks for any help
marc
yes, it doesnt really importing anything, itunes is up and running on network .
Quote:and running on network
The iTunes plugin only currently works for local itunes libraries. Your best bet is sharing your music folders via smb and just using XBMC's built in music library.
