Full Version: CDDA not working (Ubuntu 8.04, i386
Hello - I'm using Atlantis Beta 2 on Ubuntu 8.04/i386 installed via the personal package archives, and am having problems with it playing / ripping CDs. The CD drive is an external USB one, but cdparanoia seems to have no problems accessing it without any special configuration.
This is the xbmc.log when I insert a CD and try to play it:
09:24:55 T:3059107712 M:1746464768 DEBUG: Update - NEW at 364071:ffff6604cfc67980 00 Down SamsungDVD
09:24:56 T:3059107712 M:1745829888 DEBUG: Update - NEW at 365122:ffff6604cff64980 00 OK SamsungDVD
09:24:56 T:3059107712 M:1745829888 DEBUG: OnKey: 11 pressed, action is 7
09:24:56 T:3059107712 M:1745829888 DEBUG: Clearing cached fileitems [cdda://local/]
09:24:56 T:3059107712 M:1745829888 DEBUG: CGUIMediaWindow::GetDirectory (cdda://local/)
09:24:56 T:3059107712 M:1745829888 DEBUG: ParentPath = []
09:24:56 T:3007728528 M:1745829888 DEBUG: Running thread 3007728528
09:24:56 T:3007728528 M:1745829888 DEBUG: thread start, auto delete: 0
09:24:56 T:3007728528 M:1745829888 DEBUG: Saving fileitems [cdda://local/]
09:24:56 T:3007728528 M:1745829888 DEBUG: -- items: 13, sort method: 0, ascending: false
09:24:56 T:3007728528 M:1745829888 DEBUG: staticThread, deleting thread graphic context
09:24:56 T:3007728528 M:1745829888 DEBUG: Thread 3007728528 terminating
09:24:56 T:3059107712 M:1745829888 DEBUG: RetrieveMusicInfo() took 10 msec
09:24:56 T:3059107712 M:1745829888 DEBUG: Sort, sorting took 0 millis
09:24:56 T:2919549840 M:1745829888 DEBUG: Running thread 2919549840
09:24:56 T:2919549840 M:1745829888 DEBUG: thread start, auto delete: 0
09:24:56 T:2939992976 M:1745829888 DEBUG: Running thread 2939992976
09:24:56 T:2939992976 M:1745829888 DEBUG: thread start, auto delete: 0
09:24:56 T:2927942544 M:1745829888 DEBUG: Running thread 2927942544
09:24:56 T:2927942544 M:1745829888 DEBUG: thread start, auto delete: 0
09:24:56 T:2939992976 M:1745829888 DEBUG: staticThread, deleting thread graphic context
09:24:56 T:2939992976 M:1745829888 DEBUG: Thread 2939992976 terminating
09:24:56 T:2919549840 M:1745829888 DEBUG: staticThread, deleting thread graphic context
09:24:56 T:2919549840 M:1745829888 DEBUG: Thread 2919549840 terminating
09:24:56 T:2927942544 M:1745829888 DEBUG: staticThread, deleting thread graphic context
09:24:56 T:2927942544 M:1745829888 DEBUG: Thread 2927942544 terminating
09:24:56 T:3059107712 M:1745829888 DEBUG: Load defaultFolderBackBig.png: 2.7ms (bundled)
09:24:56 T:3059107712 M:1745829888 DEBUG: Load defaultAudioBig.png: 1.9ms (bundled)
09:24:56 T:3059107712 M:1745829888 DEBUG: Load list-focus.png: 0.1ms (bundled)
09:24:57 T:3059107712 M:1745829888 DEBUG: Update - NEW at 366373:ffff6604cff64980 00 OK SamsungDVD
09:24:57 T:3059107712 M:1745829888 DEBUG: OnKey: 11 pressed, action is 7
09:24:57 T:3059107712 M:1745829888 DEBUG: new file set audiostream:0
09:24:57 T:3059107712 M:1745829888 DEBUG: CPlayerCoreFactor::GetPlayers(cdda://local/01.cdda)
09:24:57 T:3059107712 M:1745829888 DEBUG: SECTION:LoadDLL(Q:\system\players\dvdplayer\avutil-51-i486-linux.so)
09:24:57 T:3059107712 M:1745829888 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/avutil-51-i486-linux.so
09:24:57 T:3059107712 M:1745829888 DEBUG: SECTION:LoadDLL(Q:\system\players\dvdplayer\avcodec-51-i486-linux.so)
09:24:57 T:3059107712 M:1745829888 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/avcodec-51-i486-linux.so
09:24:57 T:3059107712 M:1743851520 DEBUG: SECTION:LoadDLL(Q:\system\players\dvdplayer\avformat-51-i486-linux.so)
09:24:57 T:3059107712 M:1743851520 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/avformat-51-i486-linux.so
09:24:59 T:3059107712 M:1743417344 ERROR: Open - error probing input format, cdda://local/01.cdda
09:24:59 T:3059107712 M:1743417344 ERROR: Init: Error creating demuxer
09:24:59 T:3059107712 M:1727590400 DEBUG: CFileCache::Open - opening <01.cdda> using cache
09:24:59 T:2895416208 M:1727590400 DEBUG: Running thread 2895416208
09:24:59 T:2895416208 M:1727590400 DEBUG: thread start, auto delete: 0
09:24:59 T:2895416208 M:1727590400 ERROR: file cdda: Reading 52 sectors of audio data starting at lsn 0 failed
09:24:59 T:2895416208 M:1727590400 INFO: CFileCache:Tonguerocess - Hit eof.
09:24:59 T:3059107712 M:1727590400 INFO: PAP Player: Playing cdda://local/01.cdda
09:24:59 T:3059107712 M:1727590400 DEBUG: PAPlayer::CreateStream - initialized. sample rate: 44100, channels: 2, period size: 940, buffer size: 15052 period duration: 21333
09:24:59 T:2887023504 M:1727590400 DEBUG: Running thread 2887023504
09:24:59 T:2887023504 M:1727590400 DEBUG: thread start, auto delete: 0
09:24:59 T:2887023504 M:1727590400 DEBUG: PAPlayer: Thread started
09:24:59 T:3059107712 M:1727332352 DEBUG: Load defaultAudioBig.png: 2.8ms (bundled)
09:24:59 T:2887023504 M:1727332352 DEBUG: Playback has started
09:24:59 T:2887023504 M:1727332352 ERROR: CAudioDecoder: Error while decoding 1
09:24:59 T:3059107712 M:1727332352 DEBUG: Load list-focus.png: 0.3ms (bundled)
09:24:59 T:3059107712 M:1727332352 DEBUG: Load defaultAlbumCover.png: 2.8ms (bundled)
09:24:59 T:3059107712 M:1727332352 DEBUG: CGUIInfoManager::SetCurrentSong(cdda://local/01.cdda)
09:24:59 T:3059107712 M:1727332352 DEBUG: LoadMusicTag: loading tag information for file: cdda://local/01.cdda
09:24:59 T:3059107712 M:1727332352 DEBUG: Loading additional tag info for file cdda://local/01.cdda
09:24:59 T:2895416208 M:1727332352 DEBUG: staticThread, deleting thread graphic context
09:24:59 T:2895416208 M:1727332352 DEBUG: Thread 2895416208 terminating
09:24:59 T:2887023504 M:1743073280 INFO: PAPlayer: End of playback reached
09:24:59 T:2887023504 M:1743073280 DEBUG: Playback has finished
09:24:59 T:2887023504 M:1743073280 DEBUG: PAPlayer: Thread end
09:24:59 T:2887023504 M:1743073280 DEBUG: staticThread, deleting thread graphic context
09:24:59 T:2887023504 M:1743073280 DEBUG: Thread 2887023504 terminating
09:24:59 T:3059107712 M:1743073280 DEBUG: new file set audiostream:0
09:24:59 T:3059107712 M:1743073280 DEBUG: CPlayerCoreFactor::GetPlayers(cdda://local/02.cdda)
09:24:59 T:3059107712 M:1742471168 ERROR: Open - error probing input format, cdda://local/02.cdda
09:24:59 T:3059107712 M:1742471168 ERROR: Init: Error creating demuxer
09:24:59 T:3059107712 M:1726730240 DEBUG: CFileCache::Open - opening <02.cdda> using cache
09:24:59 T:2887023504 M:1726730240 DEBUG: Running thread 2887023504
09:24:59 T:2887023504 M:1726730240 DEBUG: thread start, auto delete: 0
09:24:59 T:2887023504 M:1726730240 ERROR: file cdda: Reading 52 sectors of audio data starting at lsn 13372 failed
09:24:59 T:2887023504 M:1726730240 INFO: CFileCache:Tonguerocess - Hit eof.
09:24:59 T:3059107712 M:1726730240 INFO: PAP Player: Playing cdda://local/02.cdda
09:24:59 T:3059107712 M:1726730240 DEBUG: PAPlayer::CreateStream - initialized. sample rate: 44100, channels: 2, period size: 940, buffer size: 15052 period duration: 21333
09:24:59 T:2895416208 M:1726730240 DEBUG: Running thread 2895416208
09:24:59 T:2895416208 M:1726730240 DEBUG: thread start, auto delete: 0
09:24:59 T:2895416208 M:1726730240 DEBUG: PAPlayer: Thread started
09:24:59 T:2895416208 M:1726730240 DEBUG: Playback has started
09:24:59 T:2895416208 M:1726730240 ERROR: CAudioDecoder: Error while decoding 1
09:24:59 T:3059107712 M:1726730240 DEBUG: CGUIInfoManager::SetCurrentSong(cdda://local/02.cdda)
09:24:59 T:3059107712 M:1726730240 DEBUG: LoadMusicTag: loading tag information for file: cdda://local/02.cdda
09:24:59 T:3059107712 M:1726730240 DEBUG: Loading additional tag info for file cdda://local/02.cdda
09:24:59 T:2887023504 M:1726730240 DEBUG: staticThread, deleting thread graphic context
09:24:59 T:2887023504 M:1726730240 DEBUG: Thread 2887023504 terminating
09:24:59 T:2895416208 M:1742471168 INFO: PAPlayer: End of playback reached
09:24:59 T:2895416208 M:1742471168 DEBUG: Playback has finished
09:24:59 T:2895416208 M:1742471168 DEBUG: PAPlayer: Thread end
09:24:59 T:2895416208 M:1742471168 DEBUG: staticThread, deleting thread graphic context
09:24:59 T:2895416208 M:1742471168 DEBUG: Thread 2895416208 terminating
etc. and this repeats for every track on the CD; the front end quickly flicks over each track trying to play each one and failing.
What should I do next to diagnose this further?
