hi there just got an apple tv - setup xbmc on it..updated...launched and was working great..then as i was tweaking some xbmc settings (in the prog) it rebooted and now whenever i launch xbmc it either stalls on the xbmc logo or says exited..error status either 5 10 or 11
any ideas? what should i do
Tweaked to death
You might wipe your userdata folder and start over.
ssh into your appletv:
wipe userdata folder:
rm -rf /Users/frontrow/Library/Application\ Support/XBMC
hmm - yah i just did that - do u think the atlantis 2 update is necessary since its still being tested? this problem came only after that update....
can i not update to that or is it necessary??
Update to latest (currently Beta 2) is recommended
in fact i just reinstalled it - and after the install when i go to xbmc to update it says
"Update urls not found or corrupt!"
now what
Wait, I'll try my metaphysic skill... *concentration*...*hmhm*..
nope, doesn't seem to work.
Need to see your
logs.
got it! thanks..just restarted it and it kicked in
