Full Version: Music Videos
under the Music tab you now have music videos as an option.
how are we supposed to set that up.
if i select it, i get a black screen with some writing that is overwritten with a black box. no xbox controller buttons work to attempt to add a source.
the only way out is the back button.
any suggestions on how i am using this incorrectly?
It is linking to the music videos in the library so you need to have source(s) set up with music videos (set content to be music videos) in them and them scraped into the library.
ok. i will give it a go.
thanks.
alienagenda Wrote:ok. i will give it a go.
thanks.
Dont be too hopeful on this one... its not skunkmonkees fault... or anything to do with mediastream skin..
but the mtv scrappers thats included is crappy at best...
you are almost better off consulting the wiki on how to create your own NFOs for the music videos...
