Full Version: [LINUX] HOW-TO configure Soundgraph iMON VFD/IR Receiver (used by many HTPC chassis)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
noumenon:
I used your files and put them in the locations you listed and xbmc still DOES NOT see the remote.
Again, irw can talk to the remote just fine.
Reprogramed my Harmony to be a imon.. I get double input on keypresses in irw... which is fine... just some tweaking there.
Suggestions?
EDIT: I did have to create a keymaps folder inside of userdata... does that mean something went wrong with my install?
like I said, I never got it to work in the userdata folder. Delete the Lircmap and keymaps you've put there and place the files in:
/usr/share/xbmc/system/Lircmap.xml
and
/usr/share/xbmc/system/keymaps/remote.xml
noumenon
[double post]
OK...
Formatted and following these guides to the letter, in order... adding no additional steps...
1) http://wiki.xbmc.org/?title=XBMCbuntu#In...nal_Ubuntu
2) http://www.kennynet.co.uk/2009/03/30/ubu...-152c0038/
3) http://www.xbmc.org/forum/showpost.php?p...tcount=206
Directional keys are not working....
If XBMC is in screensaver mode, any key OTHER THAN THE ARROW KEYS AND ENTER on the RM100 will "wake up" XBMC... I'm getting somewhere it seemsSmile
I double checked that the codes being reported by irw are the same ones in the lircd.conf.imon-antec-veris file that you get from Kenny's part of the setup... and they all match.
irw output from RM100 remote:
289115b700000201 00 KEY_POWER Antec_Veris_RM200
0200002a00000201 00 KEY_BACKSPACE Antec_Veris_RM200
2aa515b700000101 00 KEY_UP Antec_Veris_RM100
0200006500000201 00 RightMenu Antec_Veris_RM200
29a515b700000101 00 KEY_LEFT Antec_Veris_RM100
0200002800000201 00 KEY_ENTER Antec_Veris_RM200
2ba515b700000101 00 KEY_RIGHT Antec_Veris_RM100
28a395b700000201 00 KEY_VOLUMEUP Antec_Veris_RM200
289515b700000101 00 KEY_DOWN Antec_Veris_RM100
289395b700000201 00 KEY_CHANNELUP Antec_Veris_RM200
28a595b700000201 00 KEY_VOLUMEDOWN Antec_Veris_RM200
2b9595b700000201 00 KEY_MUTE Antec_Veris_RM200
288795b700000201 00 KEY_CHANNELDOWN Antec_Veris_RM200
298315b700000101 00 KEY_REWIND Antec_Veris_RM100
2a8315b700000101 00 KEY_PLAY Antec_Veris_RM100
2b8315b700000101 00 KEY_FASTFORWARD Antec_Veris_RM100
2ab195b700000201 00 Go Antec_Veris_RM200
Anyone?
It sucks being this close....
Tarantulas Wrote:I've got everything working but the directional keys... any idea?
on the logitech or the original remote? if its on the logitech use learn raw and just copy them from the original remote.
if its on the original remote... no idea.
noumenon
noumenon Wrote:on the logitech or the original remote? if its on the logitech use learn raw and just copy them from the original remote.
noumenon
With the Logitech programed for emulate an iMon remote (giving RM200 codes according to irw), XBMC does not recognize when you press the little directional pad in the middle of the remote. Nor does it do anything if you press the "select" key, the play key, or the FF type keys.
Using the RM100 that shipped with the case (giving RM100 codes according to irw), XBMC does not recognize when you press the little directional pad in the middle of the remote. Nor does it do anything if you press the "enter" key, the play key, or the FF type keys.
However, XBMC will come out of screen saver mode if you press any other key, it wakes up.
So, its coming up in irw but not xbmc?
change the lircmap around then... assign new codes to it. play with it.
I've been playing with it for like 10+ days at 3 hours a day.... I'm kind of just wanting someone to wave the magic wand at this point.
don't have one of those, I'm afraid.
noumenon Wrote:So, its coming up in irw but not xbmc?
How?
Also, your keymap.xml has seem to have disappeared off pastebin.
And I just noticed for the first time that there are several missing obc statements from your Lircmap.xml
Also, nothing on the XBMC site makes any reference to remote.xml... everything talks about Keymap.xml... what is different about your set up?
If you do respond, please be as verbose as possible.
Messing around with this... I was able to get the power off key to shut down the case... and the "go" key worked sort of like a back button.
But then I lost video after a reboot... didn't know what happened, and blew it away again.
Turns out if you don't have /usr/share/xbmc/system/Keymap.xml you don't get video after launching XBMC
So now I'm back to where I started... and am so tired, I forgot what I did to get that extra but further.
Tarantulas Wrote:I'm begging you for help....
Please stop dangling a carrot on a string in front of me.
You need to have more patience before reposting.
the keymap was split into multiple keymaps, remote references, obviously, a remote control. this is standard for xbmc.
There are not missing "obc statements", rather the obc numbers are not without gaps. I did that when i was playing around with the numbers. Change the obc number of a command that isn't working in Lircmap.xml, then make it match in the remote.xml.
