XBMC Atlantis release is available in the update menu in XBMCLauncher!
Please make sure to update to XBMCLauncher 0.6 _first_, as 0.6 fixes some compatibility issues.
Updated loader to 0.6 then applied Atlantis update.
All my SMB shares seem to have disappeared from my video sources and I now haver a load of new ones whic may be directories or partitions on the AppleTv itself (there's an OSBOOT entry, Homes, Desktop and others) -- is this normal?
Have re-added the 2 shares I had using add.
Apple movie trailer plugin appeared but video playback extremely stuttery - must check upscaling setting haven't changed.
Navigation of the stock interface seems significantly slower than it did before - it used to be extremely snappy going from say Video to Music etc, but there's a palpable lag now.
Saw the coloured spinning wheel on startup too in botton left hand corner of screen which I hadn't noticed before.
Only dabbled briefly so some issues may sort out after checking settings or a reboot. Just wondered if anyone else had any similar observations.
Cheers - I tried it last night, although the updates didn't appear until after I rebooted the ATV (then the remote stopped working for some reason but holding menu while rebooting again seemed to sort that out - odd!!).
Back to the point, both update .6 for launcher and XBMC worked fine - many thanks...
In XBMX I had to re-setup my video calibration as Full Screen is off screen for me - I had to do this again after stopping/restarting XBMC (I'll know later is this happens every time and if so I'll report a bug) - but no issues with my only plugin (iPlayer) and navigation speed seemed about the same.
SecretSquirrel Wrote:Updated loader to 0.6 then applied Atlantis update.
It's ok now, but getting quite a few errors and exiting when going back up a level on the remote. Not a biggy though.
