Full Version: No autoresume for m2ts files
Using XBMC 8.10 2008-11-13
In this version it is possible to play m2ts files. To add the filetype in the advancesettings.xml isn´t necessary.
If a movie is stopped the autoresume point will not create. So if the movie start the next time, it starts from beginning. The popup to ask start from the last position or from beginning doesn´t appears.
Debug Log
http://pastebin.ca/1258984
The filetype is described in the xbmc online manual
http://wiki.xbmc.org/?title=XBMC_Feature...ats/Codecs
so I think is a bug.
I make additional test with other 1:1 ripped blue-ray discs.
The summary of the tests is, that the autoresume works for the m2ts files.
I think the different to the first tests is, that the first m2ts file don´t show in xbmc the total length of the movie and it wasn´t possible to create a autoresume point.
The other two ripped blue-ray discs show the total length and the autoresume point is create and at the new start of the movie the popup (start at last position, start from beginning) appears and work.
