Full Version: Fan art supported skins
What are the skins that support Fan art ?
I couldn't use PH3 !
thanks
I know for sure.....
MediaStream
PM3.HD
Back-Row
Aeon
Horizonz
Maybe.....(I never use)
Xtv
Vision
Vision2
Vinci
Focus
Does NOT......
MC360
PM3.HD !! How do u use fan art on this skin? ?
I tried but didn't work at all.
Under Videos. You have to use library mode (not files mode). Have to set the view to FanArt. Need to make sure the scraper you use is set to scrape for FanArt. Do that by checking your scrapers settings.
That is how you do it.
Its also in a modded version of the original PMIII afaik...
