dimsumx Wrote:A question I've been meaning to ask, is there any reason to upgrade the the aTV after we've disabled the autoupdate, if we're only going to be using it strictly with XBMC?
It depends on your wishes to what frontrow looks like for you. XBMC will run on the new atv upgrade aswell as the old one (just need some re-patching.)
If you have the most recent version of Launcher, you can turn off ATV updates:
Select Launcher > Setting > ATV OS Enabled
Setting should be set to No
Hi all,
I am having problems with this. I set Apple TV OS updates to no, but it will keep asking me. This sucks. Any solutions for this? I don't want to upgrade to 4.3 and lose my xbmc.
Ty
Piru
(2009-11-02, 17:50)davince Wrote: [ -> ]pmcd Wrote:To re-enable do we just comment out or delete that last line in hosts? No rebooting, etc...?
philip
Yes, deleting the line enables the ATV to contact the 'real' update-server again...
I'm new here, but you probably should proceed with caution, because an auto-update can/will disable your patchstick functionality.
I beg you forgive my extreme ignorance here, but could you explain where I find 'hosts' and how I delete the last line in it? I know nothing of command line.
I disabled auto-update in 2008. I was suddenly overcome with a sense of adventure and updated XBMC all the way to 11.0 from whatever was current in 2008. Now, it doesn't work at all because the AppleTV os is too old. I really need to update the AppleTV in order to use XBMC again. Thank you.
if it's blocked than how do I unblock it, or is it even possible?
First of all
pair your apple tv remote. Then you can disable auto update by going to Apple TV's system settings and going to updates.
(2021-06-10, 13:48)morvi11 Wrote: [ -> ]First of all
First of all, please check if the thread you are responding to is still relevant. Reacting to a forum thread that basically has no life in it, is not very useful.
Also, do not double-post or crosspost on this forum. We are not fans of that.
(2021-06-10, 13:48)morvi11 Wrote: [ -> ]First of all pair your apple tv remote. Then you can disable auto update by going to Apple TV's system settings and going to updates.
When you go to the apple tv system and turn of the auto-update is it possible that after a while to get notification about the new update or when you turn it off you don't get any notification?
