Kewl !
Hopefully there is a new USB creator for MAC/WIN following closely behind with the 0.7 inside it
launcher 0.7 is currently in testing and is therefore not yet available through update in Launcher itself.
This release will fix some of the problems with ATV 2.3 but unfortunately not all. There are problems when you start xbmc/boxee but nothing shows up on screen. This happens when in 720p or 1080p mode. Here's how you get back to Launcher if this happens:
Boxee:
- hit menu 2 times
XBMC, 2 options:
1) right, right, select, select
2) menu, menu,play,play (<- you need to be really fast for that one)
We're currently working on a solution for that screen release problem.
Besides that Launcher 0.7 has few new features:
-fix some (but not all) ATV 2.3 issues
-universal-mode support
-enabling/disabling of ATV autoupdates
cheers,
stephan
Sounds exciting .. and brilliant as always.
Will wait on pins 'n needles for the final release - tested and ready to roll out into the world of ATV
0.8 seems to be up - what does it add?
SecretSquirrel Wrote:0.8 seems to be up - what does it add?
Bugfixes to XBMCLauncher 0.7
