2008-11-23, 19:38
Hi, to give you a little background about my self, I use plex in my entertainment center because i have access to a mac. However in the living room I only have a pc so i thought i would use xbmc. Ive set up the shares but none of my movies or tv shows will scrap at all.
here is the folder arrangement
Tv Shows/Two and a Half Men/Season 1/ Two and a Half Men-S01E01.mkv
For Movies it is
Movies/Action/inside man.mkv
all i have done is start xbmc (8.10) and set the content and then try to add the sources. when i scan the directory nothing happens.
I have tried to use the advancedsettings.xml, but i dont know where to put it (im using vista by the way) and even if i did im unsure about how to set up the scrapper settings. what is odd though is that Plex finds and scraps all this media automatically. The other thing that is odd is it was able to add one tv show which was Avatar the last airbender for the kids and it is set up the same way as above.
Any ideas or help.
Thank you
For Movies it is
Any ideas or help.
Thank you
