I got a bunch of trailers from apple.com/trailers in the hdmov container and I'm wondering if there is a way to enable them to be played back in xbmc? Currently it can't seem to see them. It can see mkv files though.
Is there a way for me to be able to play those files back? MPlayer in the mythtv front end can see and play them back.
My system is Mythbuntu 8.10 with a amd 4600+ cpu with 2 gb of ram and a 7600GT video card.
HD .mov files play back correctly here (just played the Star Trek 1080p trailer). what do you mean by 'XBMC can't see them' ?
The file extension is .hdmov not .mov. Any idea on how to make it show up?
If it's just a matter of getting xbmc to SEE the files, just add it to the list in XBMC/xbmc/Settings.cpp
to: g_stSettings.m_videoExtensions = ...
then recompile.
If that works, please submit a bug report and patch.
TheUni
So it's hardcoded in the code? That's not very flexible
Can the dev's add it to some file thats part of the settings that I can then edit in the future? It's not nice when something like this is hardcoded.
Of course I could also just use the mkvtoolnix merge utility to put them in an mkv file instead. I'll try that instead.
VDRfan Wrote:What about reading the Online Manual (link in my sig)? .. Advancedsettings.xml - videoextensions
BTW, I have added my advancedsettings, to contain some movie ext in my pictures. That will say, I want to be able to watch clips taken with my camera, when watching the pictures.
I can now see the movies, but not play them. Is it possible to do like I did, or do I have to do something else?
/Söder
Sweet. Lets hope that works then.
Update: did not work.
I set the file /home/username/.xbmc/userdata/Advancedsettings.xml to this:
Quote:<videoextensions>
<add>.hdmov</add>
<remove></remove>
</videoextensions>
pyrates Wrote:Sweet. Lets hope that works then.
I guess its the same as for me then. Can you see the files?
I can see the files, but cant play them. I guess that xbmc isnt programed to play movies in the pictures menu.
/Söder
.. most likely due to a the missing <advancedsettings>...</advancedsettings> tags
soder
Right, music is for music (and mvids) only.
VDRfan Wrote:.. most likely due to a the missing <advancedsettings>...</advancedsettings> tags
@soder
Music?
What I mean is, that I want to be able to play my video clips from my digitial camera, which are in the same folder as my pictures. Shouldnt that be possible in some way?
/Söder
hmm if that's it, thank you
Will try that then.
Oops, dunno why i said "music", should be pictures ofc. Best practise is to add the given source to the video section to play the recorded videos.
VDRfan Wrote:Oops, dunno why i said "music", should be pictures ofc. Best practise is to add the given source to the video section to play the recorded videos.
Sure, but mostly I want to play the video with the pictures..
pic1.jpg, pic2.jpg, mov3.mpeg. pic4.jpg.
I think the guys should make that work, and maybe an option NOT to play the movies in a slideshow...
EDIT: Please. =)
/Söder
@soder
Yep that was it. Thanks. So now I have this:
I set the file /home/username/.xbmc/userdata/advancedsettings.xml to this:
Quote:<advancedsettings>
<videoextensions>
<add>.hdmov</add>
<remove></remove>
</videoextensions>
</advancedsettings>
