Full Version: Organise movies
Hello
Does anyone know of an easy way to put all of my movies in there own seperate folder? Right now i have about 250 movies all in the same directory. Manually creating a folder for each is going to be a bitch.Sad
Thanks in advance.
Would this work:
http://www.monkeyjob.com/FoldMonk/FAQ/Cr...e-File.htm
I haven't tried it myself.
That worked perfect. Thanks a lot.
Is there any programs that anyone knows of that can do something similar, putting movies into genre folders?
joebrady Wrote:Is there any programs that anyone knows of that can do something similar, putting movies into genre folders?
do you have something that lists what genre it should be in? (.nfo / xml / txt file)
If not, the movie (if listed on imdb) could be searched for and the genre returned, however most movies fall into multiple genres.
Or are you looking for a manual type of gui driven app that can do it?
