2008-11-25, 01:35
This may be by design, but I want to make sure its not a bug just appearing on my system before putting in a proper feature request. Using the Disable Mouse option, the XBMC pointer is disabled, but only replaced with the linux one.
Is this intended behavior? The mouse can't actually do anything except move about the screen, which almost makes things worse because it just ends up confusing new users when they try to use it. Optimally, I think it should be completely disabled functionally (as it is already) and visibly, if possible.
