I just installed both via the patchstick and everything worked fine (ie boots into the atv fine and shows both apps on the right side of the menu as it should) After I installed I decided to go ahead and update xbmc, boxee and the launcher before running anything.When I ran boxee the screen went black and I was forced to kill finder. I went ahead and ran xbmc with the same results. I ran boxee a second time and it launched fine.
Is this normal response from both xbmc and boxee on the apple tv? btw xbmc has never launched correctly yet.
raginbullsht Wrote:I forgot to add details
I am using 1.0.b10 usb creator
Used 2.0.2 dmg for boot.efi
running 2.0.2 on atv
pastebin of log boxee http://pastebin.com/m3801100f
pastebin of log xbmc http://pastebin.com/m7d1fbd1f
like to see /Library/Logs/Console/501/console.log
pastebin it please.
http://pastecode.com/19234
Here is the console log. I think I have figured out my issue. It appears the atv is not properly detecting my tv. I need to switch my source on my television from the atv to cable then switch it back. I can see xbmc and make setting changes now, but it still happens everytime I restart xbmc or boxee
Is that atvusb-creator-1.0.b10 or atv-win-1.0.b10, if atv-win-1.0.b10, XBMCLauncher is the wrong version, remake/patch with atv-win-1.0.b11.
davilla Wrote:Is that atvusb-creator-1.0.b10 or atv-win-1.0.b10, if atv-win-1.0.b10, XBMCLauncher is the wrong version, remake/patch with atv-win-1.0.b11.
I have the exact same problem. I am using ATV2.3, atvusb-creator-1.0.b10 and XBMC 8.10 - my problem also temporarily solves itself if I toggle input
Smokey18 Wrote:Hi,
HDMI? if yes, know issues with the current XBMCLauncher. The next version will resolve it.
davilla Wrote:HDMI? if yes, know issues with the current XBMCLauncher. The next version will resolve it.
Ahh.. OK.. Sure using HDMI
Well.. no problem. Will switch to component. Thanks a lot for the reply !
