2008-11-27, 15:06
I'm currently building an XBMC-Linux based HTPC and thought I'd share the experience, in the hope that it will be useful to others.
Goals
Background
I already have two HTPCs, Windows XP based, using ZoomPlayer and DVB Viewer (one driving a LCD TV in the bedroom, the other driving a projector in an dedicated HT room). Additionally, I'm using two XBOXen with XBMC each driving old-style CRT TVs. Media files are on a central server, in various formats (DVD, BR, .mkv, .avis, the works), live TV is provided using old-style star-topology DVB-S cabling. At least Fast Ethernet is available in all rooms.
One of the XBMC/CRT combos is now to be replaced with a larger LCD TV. Also, since the room it is in has no DVB-S cable, I've decided to look into streaming based live TV distribution, possible using a MythTV server.
I've looked at various options for media playback (PS3, Popcorn Hour etc.), however, since I was generally very happy with the XBMC UI, I decided to try and build a XBMC-Linux based HTPC from scratch.
Equipment used
TV: Samsung LE37-A616 Full HD. I already have a Samsung M86 in the bed room, and since I'm reasonably happy with the picture quality and esspecially the ability to playback 24p and 50p nativly without judder, I decided to go for Samsung again.
PC: Shuttle SN78SH7 Barebone. Acceptable form factor, Geforce 8200 board with HDMI out. Equipped with 2GB RAM and an Athlon X2 6000+.
IR: Igor USB plug and a spare remote (which came with a TT S2-3200 DVB card)
Base OS: Ubuntu 8.10 server edition. Server edition mainly to have a minimum base installation to build upon.
XBMC is being build from SVN, mostly since the refresh rate adapation options are not yet available in PPA.
Best Regards,
Olli
Goals
- HTPC to support media playback and live TV (as a MythTV client)
- Display device is a Full-HD LCD-TV, Audio and Video to be provided via HDMI
- Judder-free display with automatic 24 Hz, 50 Hz and 60 Hz refresh rate switching
- Playback of VC1/H.264 up to 1080p
- IR remote control
- Ability to switch to network booting later on
Background
Equipment used
Best Regards,
Olli
