Full Version: Software menu and running Fixperm from scripts
As the title suggests is anyone having a problem with this?
I go and try to install a plug in say 'nitoTV for instance it downloads and supposedly installs then asks me to goto the scripts menu and run fixperm. I go to scripts and then the UI is restarted and the plugin isn't installed.
I am running AppleTV on 2.0 after a fresh factory settings reboot and patchstick installed from davilla (fantastic work btw you efforts and work are truly appreciated).
Is this a problem on later firmwares say 2.1 or 2.2 ?
