Is there a way of making a control visible depending on what month it is?
I thought this would work, but i may misunderstand the infobool, because it doesnt.
<visible>System.Date(11-01,11-30)</visible>
edit: hmm it appears to work now.
it's not working right, but i think i have a fix. and yes the above is how it works.
edit: fixed in svn
That's wicked. Cheers.
Is the SVN build that now works something I can download and compile for Windows? I know where the instructions are, but would I have to wait for it to be ported over from Linux or anything?
it's in the linuxbranch, so you can build windows sdl or linux
