Anyone able to find the way to write a plugin for the italian
mediaset video site?
I tried some basic tests but I was not able to have a working schema nor to receive any valid video streams
Any help appreciated!
I looked very quickly to the website you have mentionned, and I think I found information which could be useful for writing your script.
Uing http header (add on firefox) I found those XML:
- Liste of video :
http://www.video.mediaset.it/vedianche/i...ttenimento
You can see entries like:
<video-summary id="scherziaparte/2007/07/20/108">
<image>bin/10.$plit/C_5_video_25284_stopframe.jpg</image>
<title>Senti chi parla</title>
<program>Scherzi a Parte</program>
<description>Scherzi a Parte</description>
<date>20/07/2007</date>
<visto>1489</visto>
<network-logo/>
</video-summary>
And one xml for a s[ecific video which includes video links:
http://www.video.mediaset.it/video/uomin...2F02%2F651
So if I use the entry above: scherziaparte/2007/07/20/108 and mix it with the video URL, I get the xml URL:
http://www.video.mediaset.it/video/scher...8312463129
<video id="scherziaparte/2007/07/20/108" code="25284">
<thumbnail>bin/10.$plit/C_5_video_25284_stopframe.jpg</thumbnail>
<urls>
<url type="wmv">scherziaparte/2007/07/Scherzi_GiadaDeblank2.wmv</url>
<url type="flv"/>
</urls>
<description>
Un macchinario avveneristico per leggere il pensiero
</description>
<category ads="true" area="intrattenimento" classname="intrattenimento" id="scherziaparte/2007/scherzi">
<airtime/>
<program-logo>/bin/54.$plit/C_5_aggregazione_38_grafica_logo.gif</program-logo>
<program-link/>
<network-logo>/img/logo_network_canale5.png</network-logo>
</category>
<visto>1517</visto>
<rating stars="5" voti="6"/>
</video>
Here it is, the video URL is in it!
I think it is a good starting point, I hope it help.
maybe I got it wrong, but I can't stream the video with the URL built as instructed.
Did you try to open the video streams (wmv or flv)?
for example:
http://www.video.mediaset.it/video/scherziaparte/2007/07/Scherzi_GiadaDeblank2.wmv
is not is video stream!
Yes you're right, I tried and it doesn't work.
You have to dig and look what are the request sent using http header for instance.
The issue could be also the use of cookie which return differene thing depending on what is defined in the cookie.
Sorry I cannot spent too much time on it right know, I will try to see if I can figure it out.
Just olling the answer from the server on:
http://www.video.mediaset.it/video/scher...blank2.wmv
GET /video/scherziaparte/2007/07/Scherzi_GiadaDeblank2.wmv HTTP/1.1
Host: www.video.mediaset.it
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.4) Gecko/2008102920 Firefox/3.0.4
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
HTTP/1.x 404 Not Found
Date: Wed, 03 Dec 2008 18:33:40 GMT
Server: Apache
Accept-Ranges: bytes
Content-Length: 115
Keep-Alive: timeout=5, max=1000
Connection: Keep-Alive
Content-Type: text/html
So it seems the URL is wrong, it could be the base path since in the XML we only have:
Perhaps
http://www.video.mediaset.it/video/ is not valid for video path ...
if there is no FLV link use: mms://mediaset.wmod.llnwd.net/a2695/e1/[wmvurl]
ex. mms://mediaset.wmod.llnwd.net/a2695/e1/scherziaparte/2007/07/Scherzi_GiadaDeblank2.wmv
if there is a FLV link, it gets kinda weird. the base url is:
rtmp://217.169.112.25:80/vod/
but then the actual video url is different than what is listed on the XML page.
ex.
mediasetestero/2008/12/nipV_14_darlene.flv
mediaset_admediasetestero_2008_12_nipV_14_darlene.flv
have fun and good luck
rwparris2
Well done
, I wasn't able to find those damn URLs.
May I asked how you find it? It would help me to improved my investigation technique. Nothing came throw the header, how did you get those?
@l.capriotti
I think you have the minimum for starting now, good luck!
firebug for firefox & orbit downloader
tks you all, much appreciated!
No problem.
And to be honest, I probably wouldn't have ever looked at this if it weren't for the challenge in the title
If you need anymore help, let us know.
I do, can you speculate a little bit on the FLV video URL? I did not get the point...
The point I was trying to make is I could figure out FLV when I was looking at it before... the url provided in the xml with the video details is different from the url firefox said I was playing. AND if a FLV link was provided in said xml page, the actual wmv is different than what is provided as well.
In other words, if only the wmv filename is provided, the method I posted earlier works.
If both or only flv is provided it doesn't.
Also I only looked at 3-4 videos, but it seemed the FLV links were only present for the shorter clips, and wmv were for full length episodes. Maybe my sample size was too small.
I'll try to remember to look at it more next week when I have time.
Wireshark and trawling through the Get requests.
