2008-12-05, 08:02
Ok some background info.... been running 1.1 for years... just streaming movies etc to my xbox.... its a 1.0 xbox too if I remember right... anyways here is the log
22:56:25 M: 55758848 NOTICE: -----------------------------------------------------------------------
22:56:25 M: 55738368 NOTICE: Starting XBMC, Platform: Xbox. Built on Nov 14 2008
22:56:25 M: 55738368 NOTICE: Q is mapped to: F:\apps\XBMC
22:56:25 M: 55738368 NOTICE: The executable running is: F:\apps\XBMC\default.xbe
22:56:25 M: 55738368 NOTICE: Log File is located: Q:\xbmc.log
22:56:25 M: 55738368 NOTICE: -----------------------------------------------------------------------
22:56:25 M: 55738368 NOTICE: Unmapped drive T
22:56:25 M: 55717888 NOTICE: Mapping drive T to Harddisk0\Partition6\apps\XBMC\UserData
22:56:25 M: 55717888 NOTICE: Setup DirectX
22:56:26 M: 55689216 NOTICE: Mapping drive C to Harddisk0\Partition2
22:56:26 M: 55689216 NOTICE: Mapping drive E to Harddisk0\Partition1
22:56:26 M: 55689216 NOTICE: Unmapped drive D
22:56:26 M: 55689216 NOTICE: Mapping drive D to Cdrom0
22:56:26 M: 55689216 NOTICE: Mapping drive F to Harddisk0\Partition6
22:56:26 M: 55689216 NOTICE: Mapping drive X to Harddisk0\Partition3
22:56:26 M: 55689216 NOTICE: Mapping drive Y to Harddisk0\Partition4
22:56:26 M: 55689216 NOTICE: Unmapped drive Z
22:56:26 M: 55689216 NOTICE: Mapping drive Z to Harddisk0\Partition5
22:56:26 M: 55689216 NOTICE: load settings...
22:56:26 M: 55689216 NOTICE: Mapping drive P to Harddisk0\Partition6\apps\XBMC\UserData
22:56:26 M: 55689216 NOTICE: loading T:\guisettings.xml
22:56:26 M: 55558144 NOTICE: Getting hardware information now...
22:56:26 M: 55558144 NOTICE: Checking resolution 10
22:56:26 M: 55558144 NOTICE: Setting autoresolution mode 4
22:56:26 M: 55558144 NOTICE: No advancedsettings.xml to load (T:\advancedsettings.xml)
22:56:26 M: 55558144 NOTICE: Per AV pack settings are off
22:56:26 M: 55664640 NOTICE: q:\UserData\sources.xml
22:56:26 M: 55664640 ERROR: CSettings::Load Error loading q:\UserData\sources.xml: Line 0, Failed to open file
22:56:26 M: 50405376 NOTICE: Checking the Date!
22:56:26 M: 50409472 NOTICE: start dvd mediatype detection
22:56:26 M: 50343936 NOTICE: initializing playlistplayer
22:56:26 M: 50343936 NOTICE: DONE initializing playlistplayer
22:56:26 M: 50335744 NOTICE: load default skin:[Project Mayhem III]
22:56:27 M: 46686208 ERROR: SQLite: SQL error or missing database
Query: select iCompressCount from version
Query: alter table version add iCompressCount integer
22:56:27 M: 46686208 FATAL: Unknown exception code (0xe06d7363)
at 0x000caea8
I tried to update by just transfering over all the files... but it hangs at the splash screen
thanks all for the help... got about 5 more xbox to install XBMC after I can get this one to work
at 0x000caea8
