2009-01-03, 14:24
2009-01-03, 19:06
FYI; further development discussion on adding on-the-fly theme/backdrops changes to skins with variables based on date and time of the day, and weather conditions can be found here:
http://forum.xbmc.org/showthread.php?tid=40709
and here:
http://forum.xbmc.org/showthread.php?tid=27354
00 Rain/Lightning
01 Windy/Rain
02 Same as 01
03 Same as 00
04 Same as 00
05 Cloudy/Snow-Rain Mix
06 Hail
07 Icy/Clouds Rain-Snow
08 Icy/Haze Rain
09 Haze/Rain
10 Icy/Rain
11 Light Rain
12 Moderate Rain
13 Cloudy/Flurries
14 Same as 13
15 Flurries
16 Same as 13
17 Same as 00
18 Same as 00
19 Dust
20 Fog
21 Haze
22 Smoke
23 Windy
24 Same as 23
25 Frigid
26 Mostly Cloudy
27 Mostly Cloudy/Night
28 Mostly Cloudy/Sunny
29 Partly Cloudy/Night
30 Partly Cloudy/Day
31 Clear/Night
32 Clear/Day
33 Hazy/Night
34 Hazy/Day
35 Same as 00
36 Hot!
37 Lightning/Day
38 Lightning
39 Rain/Day
40 Rain
41 Snow
42 Same as 41
43 Windy/Snow
44 Same as 30
45 Rain/Night
46 Snow/Night
47 Thunder Showers/Night
and here:
jmadonald Wrote:how do i go about finding the correct icon number?N/A Not Available
00 Rain/Lightning
01 Windy/Rain
02 Same as 01
03 Same as 00
04 Same as 00
06 Hail
08 Icy/Haze Rain
09 Haze/Rain
10 Icy/Rain
11 Light Rain
12 Moderate Rain
13 Cloudy/Flurries
14 Same as 13
15 Flurries
16 Same as 13
17 Same as 00
18 Same as 00
19 Dust
20 Fog
21 Haze
22 Smoke
23 Windy
24 Same as 23
25 Frigid
26 Mostly Cloudy
31 Clear/Night
32 Clear/Day
33 Hazy/Night
34 Hazy/Day
35 Same as 00
36 Hot!
37 Lightning/Day
38 Lightning
39 Rain/Day
40 Rain
41 Snow
42 Same as 41
43 Windy/Snow
44 Same as 30
45 Rain/Night
46 Snow/Night
2009-01-03, 22:17
timdog82001 I did expand your fanart-pack.
If you want to I can upload them.
2009-01-04, 02:19
That would be excellent, Waffa
2009-01-04, 03:16
Here they are. megaupload
If you like them then copie them into Timdog82001 weather-pack.
All pictures are 16:9 but different sizes.
Got also all lot off backgrounds 6000+, all sorts of categories. 16:9 and mostly HD.
Did resize them for xbox use to 1280 x 720. Can make a torrent file of them.
2009-01-15, 03:53
http://forum.xbmc.org/showthread.php?p=2...post269870
Short tutorial of how to add this functionality to Horizonz, thanks to Cranial
2009-01-16, 21:47
Can somebody tell me what the path should be when using this in XBMC Live?
I copied them on the root of my memorystick in Backdrops
If I go to a terminal, the xx-folders are in /mnt/Backdrops/Weather, so I set the path in the xml's to mnt/Backdrops/Weather/, but I only get a black screen in XBMC...
[edit]
Hm, this might be the problem:
http://forum.xbmc.org/showpost.php?p=270...stcount=15
I'll have to figure out how to update XBMC Live to the latest SVN, I guess
[edit]
2009-01-18, 19:09
Nice Waffa...the more eye candy the better, thanks. Also, thanks of course to timdog82001 and anyone else working on this as well. For some strange reason I am addited to the weather toys.
2009-01-19, 00:28
Fire69 Wrote:I'll have to figure out how to update XBMC Live to the latest SVN, I guess
Yeah, is that possible? And how do I do that, I know how to use Subversion and make and stuff but is it possible to change XBMC version in XBMC Live?
(EDIT)
Yes it's possible... added the svn ppa to apt sources file and made a apt-get install xbmc... now running latest svn =)
https://edge.launchpad.net/~team-xbmc-svn/+archive/ppa
2009-01-28, 20:49
Thanks for all the hard work and posting your .xml files.
2009-01-30, 11:02
I added this to my xbox running the pm3hd skin using this post
http://forum.xbmc.org/showpost.php?p=254...stcount=17
When I add it the images cycle through super fast. Is there a way to slow it down? I'm running the xbox build from 12-30-2008
2009-01-30, 11:04
As well is there a way to have this run on the main page under the weather section so when you scroll up and down it shows the image for the correct condition opposed to having to enter the weather area?
2009-01-30, 19:46
kizer Wrote:I added this to my xbox running the pm3hd skin using this post
http://wiki.xbmc.org/?title=MultiImage_Control
That should tell you all you need to know, but as a hint, look at the tag <timeperimage>
2009-01-30, 19:48
kizer Wrote:As well is there a way to have this run on the main page under the weather section so when you scroll up and down it shows the image for the correct condition opposed to having to enter the weather area?
sure. The exact implementation depends on what skin you're using, but as far as the multiimage control itself, you don't need to change anything about it whether its in the weather window, home window, or anywhere else for that matter.
2009-01-31, 00:10
Thanks Tim I'll give it a looksee. I'm running PM3HD and will give it a tinker this evening.
On a side note it looks like I'm 30minutes north of you geographically.
