Full Version: New Weather properties - all weather info can now be set in any window
As of revision 16480, you may now display all weather info in any window. you may also use thes properties in the weather window instead of id="#"
Accessing them from another window include "Weather" for the window:
<info>Window(Weather).Property(Current.FeelsLike)</info>
List of properties:
PHP Code:
#id,    property
10, <info>Window.Property(Location)</info>
11, <info>Window.Property(Updated)</info>
21, <info>Window.Property(Current.ConditionIcon)</info>
22, <info>Window.Property(Current.Condition)</info>
23, <info>Window.Property(Current.Temperature)</info>
24, <info>Window.Property(Current.FeelsLike)</info>
25, <info>Window.Property(Current.UVIndex)</info>
26, <info>Window.Property(Current.Wind)</info>
27, <info>Window.Property(Current.DewPoint)</info>
28, <info>Window.Property(Current.Humidity)</info>
info>Window.Property(Current.FanartCode)</info>
Day0
31
, <info>Window.Property(Day0.Title)</info>
32, <info>Window.Property(Day0.HighTemp)</info>
33, <info>Window.Property(Day0.LowTemp)</info>
34, <info>Window.Property(Day0.Outlook)</info>
35, <info>Window.Property(Day0.OutlookIcon)</info>
info>Window.Property(Day0.FanartCode)</info>
Day1
41
, <info>Window.Property(Day1.Title)</info>
42, <info>Window.Property(Day1.HighTemp)</info>
43, <info>Window.Property(Day1.LowTemp)</info>
44, <info>Window.Property(Day1.Outlook)</info>
45, <info>Window.Property(Day1.OutlookIcon)</info>
info>Window.Property(Day1.FanartCode)</info>
Day2
51
, <info>Window.Property(Day2.Title)</info>
52, <info>Window.Property(Day2.HighTemp)</info>
53, <info>Window.Property(Day2.LowTemp)</info>
54, <info>Window.Property(Day2.Outlook)</info>
55, <info>Window.Property(Day2.OutlookIcon)</info>
info>Window.Property(Day2.FanartCode)</info>
Day3
61
, <info>Window.Property(Day3.Title)</info>
62, <info>Window.Property(Day3.HighTemp)</info>
63, <info>Window.Property(Day3.LowTemp)</info>
64, <info>Window.Property(Day3.Outlook)</info>
65, <info>Window.Property(Day3.OutlookIcon)</info>
info>Window.Property(Day3.FanartCode)</info
new labels added
I thought that I might as well also here link to semi-related threads discussing the new Weather 'FanArt' Backdrop support that too has been added to XBMC SVN very recently:
Weather 'FanArt' Backdrops (based on current weather conditions):
http://forum.xbmc.org/showthread.php?tid=40709
Theme change on-the-fly (variables based on date and time of the day, weather, etc.):
http://forum.xbmc.org/showthread.php?tid=27354
Weather FanArt Pack (Backdrops with different weather conditions):
http://forum.xbmc.org/showthread.php?tid=41650
All used together are capable of giving an additional 'WOW' factor to any skin for XBMC Cool
Is this something that has to be set up by the skinner, it is it user controlled as some of the other fanart is?
the last link gamester posted should have instructions. or at least one of those links does.
