2008-12-08, 15:09
Hi, can anyone tell me how to get the webserver working??
After searching through the forums and the wiki I am aware that there is a problem with password field, and that the username should be xbox,
however, whatever combination I use nothing helps.. If I leave the port at 80 internet explorer goes straight to a 404, if I change the port to 8080 it does give me a login box (sometimes) however whatever combination of username and passwords I use it will either go to an "unauthorised access page" or straight to a 404
where should default.asp be located (just so I can check it is there) and also where are the username and password held (so I can check that file hasn't got corrupted??)
